  3. Display operating point
  • Subscribers 136
  • Views 29114
santoshvema
santoshvema over 17 years ago
Hi, I am using CMOS 90nm technology in cadence and I just wonder how I can display the region of operation, gm, and id etc for my transistors. I tried the same steps that we used to do for cmosp18 technology in cadence but I couldn't succeed. Thanks. -Santosh
  • skillUser
    skillUser over 17 years ago
    Hi Santosh,
    You might need to look at the cell level CDF for one or more of the cells in question (Tools -> CDF -> Edit from the CIW menus), and in particular look at the interpreted labels section to ensure that there are settings there, and that they seem appropriate.  You should be able to compare any settings with the previous cmosp18 technology.  You may need to refer back to your technology provider if things do not seem correct.  This is most likely to be a technology set up problem rather than a tool issue, especially since you stated that this worked before.
    Lawrence.
  • Grego
    Grego over 17 years ago
     I assume you mean by using Results->Annotate in ADE? Assuming Spectre is your simulator
    If the devices are defined as subcircuits then you need to also check the CDF->simInfo->spectre section for the device.
    Look at the opParamExprList for dc operating points and optParamExprList for transient op points.
    The parameters would need to be defined here if the models were subcircuits and they wanted the results to be defined based on component values from within the subcircuit.
  • naderi
    naderi over 17 years ago
     I also have similar problem Cadence2007a, with STM CMOS90nm technology. The operating point data are not displayed beside the transistors in the schematic. I tried "Edit > Component display" from Virtuoso schmatic editor and also "Results > Annotate > DC operating points " in the ADE. But none of them show the data. However, by selecting a transistor using "Results > print > DC operating points" I can take a print of all data for one transistor.
    I wonder if there is any solution for this issue.
    Ali
  • tkhan
    tkhan over 17 years ago
    I tried the method described skillUser but for another PDK (ibm cmos8rf 130nm) and it still wouldn't display the op points that I wanted. I suppose you need to have write permissions on the PDK to change CDF parameters?
    I'm curious if santoshvema and naderi are studying at Canadian schools like myself? In that case I don't think its possible to modify the PDK because we have a network installation of the PDK and Cadence tools. Best to check with your STC and try to get a local installation of the PDK.
    Also if you're doing a DC sweep you might want to load a .scs file with something along the lines of
    save * sigtype=all
    to save the results of the entire parameter sweep. Then you can check tools->results browser->dc-dc to see how all the dc op points vary with the parameter being swept. (that particular command might be a bit overkill, check spectre -h save for a more appropriate save command)
  • ECILCadence
    ECILCadence over 10 years ago
    Pls check your model files..these may be hspice model. we also faced the similar problems when using hspice models but resolved it by using spectre model files.
    regards
  • FormerMember
    FormerMember over 6 years ago in reply to naderi
    Hi Naderi, I have a similar issue with one of the instances, N_12HVTRF. The annotation does not happen, however when I do print dc operating points, I get all the results needed. So, Did you get a solution to this issue? Would be helpful if you could reply. Thank you.
