  3. Analog Layout: interdigitization
  • Views 20445
luca magnelli
luca magnelli over 17 years ago
I'm approaching to analog layout with Virtuoso XL. I have to realize the layout of a simple current mirror (2 transistors) and, for matching purposes, I'd like to realize it using an inter-digitized (or common centroid) arrangements.
There is a way, in Virtuoso XL, to merge 2 or more instances in order to form an inter-digitated one? It seems to me that, starting from a schematic entry and generating the layout from this source, Virtuoso XL only gives separate instances and the only thing to do is routing them.
Can anyone show me the procedure for activating transistors inter-digitization in Virtuoso XL?
Luca
  • craigth
    craigth over 17 years ago
    Luca, You didn’t state which IC release and database that your using. The solution recommendations will be different between IC 5141 VXL and IC61 VLS XL.   If you are using IC61 VLS XL then there are several ways you can accomplish this task.   First, you can define constraints using either the Circuit Prospector Assistant which will locate occurrences of structures and devices (e.g. current mirror) on the schematic and automatically apply the appropriate constraints. Or you can manually apply the constraints to the structures and devices using the Constraint Manager Assistant. Using the constraints assigned (e.g. Matched Parameters, Symmetry, Module Generator, etc.) You can find both of these documented in the IC613 Virtuoso Unified Custom Constraint User Guide.  There is also a constraint and feature available in VLS GXL called Module Generators or Modgens. Module Generators are designed to provide a way to generate multiple PCell instances into a complex, highly matched and structured array. Modgens are documented in the IC 613 Virtuoso Analog Placement User Guide.
    If you need assistance I suggest that you contact Cadence Customer Support and/or your local Field Application Engineer.
  • luca magnelli
     Unfortunately I'm using IC 5.1.41, can you suggest me a similar procedure for this release?
    Thanks.
    Luca
  • craigth
    Luca,
    You maybe able to use the constraints in a similar way using the Group and/or Symmetry constraints available in VXL to achieve what you want. Reference the IC 5141 Virtuoso Constraint Manager User Guide.
    Unfortunately Modgens were not implemented in IC5141 VXL. They were found in the NeoCell product.  The majority of the NeoCell 3.4 features including Modgens, Analog Placer, Cell Planner and Constraints/Constraint Manager were integrated into IC61.
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
    An automatic interdigitation algorithm is pretty complex unless you use the natural capabilities of abutment in aligningthe cells. Using dbMoveFig or rodAlign on a cell does not trigger abutment during a SKILL program but if you follow the move/align command immediately with hiUpdate(), the abutment/spacing will automatially trigger. Thus, you are spared some of the messy calculations for the pcell parameters as the tool will automatically send the abutment program the correct values. Of course, your abutment program has to be working correctly.
    I do not have the algorithm I used before Cadence bought NeoLinear as it was hard to maintain and NeoCell's capabilities were better (in IC6.1 especially).
     Ted
