  3. Setting up section name while defining Library model
  • Views 16296
affaq
affaq over 16 years ago
Does anybody knows where to find right section name while setting up model library file in ADE? I get an error saying "failed to get the MPS handle" whilei try to simulate design in ADE. What is this MPS handle and how to resolve it?
Affaq
    This is related to your previous (locked, now unlocked) post.
    Typically the documentation for your PDK, or comments at the top of the model library file will contain information on the sections to use for various simulation corners. These sections are specified in the Setup->Model Libraries form, next to the model file being included.
    As I said in the other post, the issue was that spectre failed with an error because the section was not specified, and the MPS handler error is just a consequence of the simulator not starting properly.
  • kristin
    kristin over 16 years ago
    First of all you customized model files have to contain the sections, by clicking the “Edit” bottom in the Model Library Setup window of ADE to see which sections are available. Or just simply open the model files or look at any design guides if exist. Each PDK may differ in defining the model sections.
