  3. A quetion of post layout simulation
  • Replies 7
  • Views 19403
Tinaliao
Tinaliao over 16 years ago
After schematic simulation and layout extraction, I got an extracted layout, and then I did the LVS. Finally I want to do the post layout simulation using my extracted layout.
 However, I have two problems.
 1. I found that if I don't add the model library, e.g., the ami06P and ami06N, the simulation can't succeed. But  I think using ami06P and ami06N, it is using the existing models rather than the layout I draw. (I already changed the environment to be "spectre comos_sch cmos.sch extracted schematic veriloga ahdl").
2.  In addition, the simulation using the extracted layout just outputs a voltage of 0 V and the input and output current of the layout are both 0 A. I don't know the reason.
 Thank you very much.
  • tkhan
    tkhan over 16 years ago
     1. use hierarchy editor to configure your PLS testbench
    2. do you have the pins on the correct layers?
  • Tinaliao
    Thank you very much for your answer.
    1. Where is the hierarchy editor? and how to configure it?
    2. For the vdd and gnd, I use "metal1" to add pin.
    For the Vin and Vout, I use "metal2" to add pin, and use "via" to connect them with some "metal1" layer.
    For the connection place of poly and metal1, I use "cc" to connect them. I am not sure whether this is right or not?
  • Quek
    Quek over 16 years ago
     Hi Tina
    The hierarchy editor (HE) will be launched when you create a "config" view. In the library manager, go to "File->Create->New cellview" and set the tool as "Hierarchy-Editor". But I think perhaps the HE might not be needed for your case.
    Regardless of whether you use the schematic or extracted view for simulation, you will always need to include the model files. You wrote that you have already included "extracted" view in the environment. This should normally suffice as a simple way of simulating an extracted view without going through the HE.
    Just to be sure that your settings are correct, would you please go to "Setup->Environment" and provide the info in the "Switch View List" and "Stop View List" fields? Thanks.
    Is the view named as "extracted" or "av_extracted" or is it some other name?
    If you display the netlist using "Simulation->Netlist->Create", do you see many parasitic R and C in it?
    Let's first confirm if you can netlist the extracted view correctly. : )
    Best regards
    Quek
  • Tinaliao
    Hi Quek,
    Thank you very much for you answer. For the setup->environment, the information in "switch view list" is: spectre cmos_sch cmos. sch extracted schematic veriloga, and the information in "stop view list" is spectre.
    What is the view name? I named my circuit as extracted1.
    After "simulation->netlist->create raw",  I can see like "(vin vout) capacitor c=2.34363-16 m=1
    (vin gnd) capacitor c=2.3436 m=1" etc.  Is this right?
    And what's next I can check? The current into and out of my extracted circuit are all flow, and I think it may be because the contact or via connecting different layer has some problem.
    Thanks again,
    Chen
  • tkhan
    If it is the cellview name, then you should be putting extracted1 into the switch view list. If it is the cell name, you need to find out what cellview is created by your extraction tool and add that to switch view list.
    What tool are you using to extract? Diva? RCX? QRC? Diva will call the extracted cellview "extracted", QRC (and I believe RCX) will call it "av_extracted". I know that If you used QRC and told it to extract parasitics, they should appear in the netlist as pcapacitor, presistor, pinductor, pmind.
    Note that both Diva and QRC allow you to call the view whatever you want - the default is just "extracted" or "av_extracted".
    Just a minor point; still needs the view name in the switch list (or hierarchy editor) to be correct.
  • Tinaliao
    Hi tkan,
    Thank you very much. Previously I did not know I should add the name of the extracted circuit in the switch view list. I thought "extracted" just means that it simulates the extracted circuit.
    Now the problem is solved. :-)  Your answer is very helpful, thanks a again.
    Best,
    Tina
