  3. ADE L | post-layout simulation | input.scs error | missing...
  • Views 16186
ADE L | post-layout simulation | input.scs error | missing model
pitter
pitter over 16 years ago
after successful RLC extraction I got a av_extracted view, which I set in ADE Setup->Environment... in the Switch View List in order to perform post-layout simulation. The netlist is created without any error. However, when I start to run a transient simulation I get te following error:
<< ERROR (SFE-23): "input.scs" 48743: ra4289 is an instance of an undefined model met4.>>
 There is a series of errors actually, with different model names (met4, met1, poly1) and number coming after "input.scs" in the above quoted error line.
I thought, the PDK (AMS C35 0.35um process) should provide such models, but I cannot find any in the Hit Kit directory.
 Thanks for help in advance,
Kind Regards,
pitter.
  • Quek
    Quek over 16 years ago
    Hi Pitter
    Perhaps this can help to solve the problem:
    a. In the QRC form, go to "Netlisting" tab
    b. For "Parasitic Resistor Models", use "Include as comment" instead of "Include Model"
    Re-generate the extracted view and retry spectre simulation. : )
    Best regards
    Quek
  • pitter
    The problem solved!
    Many thanks Quek
  • gentle
    gentle over 13 years ago
     Hi ,
    I was having the same problem and was  able to resolve it using above steps.
    However the problem is now that i am getting same delay between input and ouput in both the simulation(prelayout and postlayout simulation) which ideally is not possible.
    does this "Include as comment" made the parasitics unaccounted.
    The include as comment only means that the "model name" (the type or layer that originated the parasitic) is included as a comment - the actual parasitic is included in both cases.
    Not sure why your pre and post layout simulation results would be the same.
