  3. ASSURA41-614: ERROR rcAddRegionTasks
  • Subscribers 133
  • Views 15278
tkhan
tkhan over 16 years ago
We recently upgraded one of our PDKs and had to switch from ASSURA32 to ASSURA41 for physical verification. I tried doing an LVS on one of my layouts and got the following error:
Compiling rules...
ERROR rcAddRegionTasks - Unexpected region task.
    Please inform Cadence of this system error.
Any ideas on what could cause this before I open an SR?
I am using:
ASSURA41  av4.1:Production:dfII6.1.4:IC6.1.4.485
IC614  sub-version  IC6.1.4.500.2
Tarek
  • tkhan
     seems to be an issue with the rules file, have to contact the foundry. this thread can be deleted.
  • tkhan
    So the foundry has hinted that this is a tool problem not a rules file problem since they can reproduce the issue but not consistently. Has anyone experienced this and if so how was it resolved? I found that the rules file do still work with ASSURA32, is there any way to check if the rules file is truly qualified for ASSURA41?
    I've seen a current CCR on this - 786653 - which is being worked on right now for one of the foundries, filed only 3 days ago. R&D are working on a version with more debugging information to help see if this sheds any light on it.
    Perhaps you could send me a direct message and we can see if it's the same foundry...
    I don't think it's something  you can resolve yourself, by the looks of things.
