  3. change the name of a net in virtuoso XL
  • Views 21234
tester
tester over 16 years ago
Dear All,
I am using ic 5.1.41 for schematic and the associated virtuoso XL for layout drawing. I have a very simple question? how do I change the name of a net?
    Wouldn't you change the net name in the schematic and then do Update Components and Nets in Layout XL? You don't want to just change the net name in the layout, because then it would be inconsistent with the schematic, surely?
  • tester
    Dear Andrew,
    Thank you very much for your reply, and here is the delimma that I am having:
    The problem that I am having is the net for vdd. I created a rectangular in metal 1 and wanted to be vdd. (I checked the property righer after the creation and it shows as net 13). Later, I created a pin with a name of "vdd!" in metal 1 and put it on top of net 13. Then I got an error messge stating that there is short between "net13" and "vdd!". Orignally, I thought to force the change of "net13" to "vdd!" since in the schematic, it has "vdd!" already. Now, it seems that I need somehow generate it from schematic. The only thing that I know is to use "generate from the source", which will override all the stuff that I have earlier, which I do not want to erase all of the work previously. I was wondering whether there is a way to just generate the protion of the interested from the schematic as needed. In this case, just the "vdd!" net and all the rest remain untouched.
    Try using menus such as Connectivity->Check->Against Source and Connectivity->Update->Components and Nets to check/update your design rather than reinitialising from scratch.
    You may just be best logging a service request via http://support.cadence.com and talking this through with an Application Engineer.
    Best Regards,
  • tester
    Dear Andrew,
    Thank you very much for your help. Per your instruction, the problem has been solved.
    Have a nice weekend!
    Tester
