  3. problem with updating vxl connectivity (IC5.1.41)
  • Views 15414
lrl12skdev
lrl12skdev over 15 years ago
 Hi All,
 I have a problem updating my layout for conectivity information. for example there is a block that was changed in the top level schematic, say some pins were added in the block. when I do in layout window "update source" then "check against source" and finally "update instance and conectivity" I still can´t see the flight lines for the new pins. I fear that if I export the layout to VCAR, it will not be routed.
Am I doing it wrong or it is really a limitation of the tool.
for a work around, I delete the instance and then  reinstanciate again by "pick from schematic" and it works.
Does anybody knows an easier way to handle this?
 best regards,
lrlsk
  • Quek
    Quek over 15 years ago
    Hi Irlsk
    I can reproduce your observations using IC5141.500.6.144 and IC614.508. I think it is a bug. Thanks for reporting it. I have filed a request to R&D to fix it. If the connectivity is not present, vcar would not be able to do the routing. I think picking the instances again from the schematic is the best approach.
    Best regards
    Quek
  • lrl12skdev
    Hi Quek,
     Thank you very much for your clarification. I would for the moment stick with the current work-around but in case there will be solution or skill script to ease the situation please let me know.
    best regards,
    lrlsk
  • Quek
    Hi Irlsk
    I need to make a correction. The problem only occurs for IC5141 and not for IC614. Previously I had some wrong data in my physConfig view. After correcting the problem, connectivity for new pin appears.
    Best regards
    Quek
