  3. LVS on mixed signal circuits
  • Replies 8
  • Subscribers 137
  • Views 20303
hon cheong
hon cheong over 15 years ago
If I would like to run LVS on a circuit that compose of both analog circuits (handcrafted) as well as digital circuits ( layout generated by Encounter), how can I do that ? while I have schematic for my analog circuits, I do not have schematic for my digital circuits ( I have VHDL code, structural verilog files generated by design compiler, as well as layout generated by Encounter).
Please advice.
Thank You.
Hon Cheong
  • Tongju
    Tongju over 15 years ago
    Hi, Hon Cheong,
    You need to get the final, gate level verilog netlist from the final database of FE (you could do it by GUI, or by tcl command "saveNetlist fileName"). This netlist could be imported into dfII (File->Import->Verilog) to create schematic views for the circuit and then, you could use your normal LVS flow to check it  together with your analog circuit.
    Tongju
  • hon cheong
    Hi Tongju,
    Thanks for your reply, it give me more insight into the LVS flow. However, since I am provided with the standard cell netlist by ARM, do I need to include the standard cell netlist (ibmrfvt.cdl)  while saving my netlist in SOC Encounter ?
    Thanks.
    Hon Cheong
  • Tongju
    Hi, Hon Cheong,
    I don't think you need to get your cdl file that describe your stdcell circuits into FE. FE only need LEF, .lib, and .cdb files for stdcells. However, you need to integrate all of those netlist files (stdcell, cdl, final gate netlist from FE, and your analog circuits) together to run your fullchip, tapeout LVS check.
    I thought that one way is to create the stdcell library in the dfII by using the gds and cdl files (I don't know whether it is possible or how to do it). Then, import FE netlist into dfII, then, you could do your TO LVS check inside dfII.
     The other way is to stitch those files together by LVS check tools. But I don't know the detailed steps. Someone in this forum may have better idea.
     Tongju
  • Kari
    Kari over 15 years ago
     Hon,
    I'm going to move this thread to the Custom IC forum. I think you'll get more help with this particular issue there.
    - Kari
  • hon cheong
     I think we can do LVS for mixed signal circuit by first convert verilog code to spice netlist, then create a schematic view from the spice netlist. Then we can do LVS just like what we did for analog circuit. I have found the solution in this link:
    http://circuitdesignworld.wordpress.com/2010/11/11/how-to-run-lvs-for-mixed-signal-circuit/
     hon cheong
  • Quek
    Quek over 15 years ago
    Hi Hon Cheong
    If you are using Assura, there is no need to manually convert your structural verilog codes to spice format. Assura can read in the verilog files and does conversion automatically. The relevant standard cell cdl files for the verilog files have to be included too.
    If you would like to first convert your verilog codes to cdl format, you can use Assura's "netReader" tool to do it. Please refer to COS solution 11288720 for more details.
    PVS is also able to read in verilog directly. The equivalent of "netReader" for PVS is "v2cdl" tool.
    Best regards
    Quek
  • hon cheong
    Hi Quek,
     Thanks for your reply. I am using Calibre. Although I can do LVS for digital circuit comparing verilog codes and layout, I wonder how is it possible to do it for mixed signal circuits. I need to interconnect my digital circuit with analog blocks. Therefore I take the simplest approach by converting all of them into schmeatic view.
     Best Regards,
    Hon Cheong
  • Quek
    Hi Hon Cheong
    Currently it looks like you are doing mixed signal lvs as follows:
    a. Import all cdl files as schematic
    b. Import all verilog files as schematic
    c. Do lvs on imported schematics and layout
    You can also do it as follows without importing cdl and verilog:
    a. Use v2lvs to convert verilog netlist to cdl format
    b. Compare with layout using toplevel cdl netlist and the converted cdl files
    Best regards
    Quek
