  3. Mark Net Configuration
  • Views 17040
TjaartOpperman
TjaartOpperman over 15 years ago
I'm getting some problems when using mark nets in VLE on IC614. When I highlight a net, all the layers in the layout gets highligted like there is some kind of short. It seems like the tool uses the layers defined under viaDefs( standardViaDefs (.. )) in the techfile to establish connectivity. I believe that the short is caused by a via definition that is used to connect the ACTIVE layer to the METAL1 layer. The ACTIVE layer is drawn over the gate of a MOS, causing the tool to interpret it as a short, when its actually electrically unconnected. So I've seen that its is possible to select Via Layers manually when using the Mark Net tool. I find this solution a bit tedious however, and I want to know if there are any alternatives?
    Mark Net in IC614 supports the idea of "Stop Layers" (you can specify that ACTIVE is stopped by POLY, so it will not follow connection under the gate of a transistor).
    This can be set up so that it is initialized automatically by creating a file called "stopLayers" in the appropriate place. Search in cdnshelp for stopLayers and it will explain how to do this.
  • Adrian Nistor
    Adrian Nistor over 15 years ago
    I think my question is related to the current subject;
    How can I "Select Via Layers for Mark Net" with different purposes ?
    The problem is that if I select for example "poly" as one layer ... it will propagate through list("poly" "drawing"), list("poly" "pin"), etc .. all possible "poly" cases, and I want only one of them.
    Best Regards,
    Adrian
    Adrian,
    There's an existing CCR  790864 asking for this in IC61X, as currently it is not possible. I would suggest you create a service request and ask for a duplicate CCR to be filed - which adds to the customers requesting this, which can help to increase the likelihood of this being done sooner rather than later (there was a lot of discussion on this CCR a few months ago though, working through some of the use model issues).
    Best Regards,
  • Adrian Nistor
     Thank you for your fast answer, I will do so.
    Best Regards
    Adrian
