  3. Transistor Finger/Multiplier does not work
  • Subscribers 133
  • Views 3836
zlo1
zlo1 over 14 years ago
Hello!
When I edit the finger/multiplier property of a transistor in schematics(pressing q), it does not make a difference in the simulation.
For example, I tried to doubling the output current of a current mirror by increasing m from 1 to 2.  But the output current remains the same.  So I checked the netlist, it shows that the transistor still have m = 1 even though I edited the finger/multiplier to 2 in the schematics.
Here is my setup:
I am using Cadence virtuoso version 6.1.  And I converted the transistor technology file from the version 5 to version 6 using the conversion tool box.
  • skillUser
    skillUser over 14 years ago
    Hi Zlo1,
    I suspect that the CDF parameter for m that you are setting on the instances is not in the output parameters (instParameters) for that device in its simInfo section for your simulator (spectre?).  Take a look under Tools -> CDF -> Edit  Since you mentioned a migration from an earlier version, perhaps the PDK or reference library for the devices changed, e.g. "m" in the older release is "mult" in the newer release.
    Hope this helps.
    Lawrence.
  • zlo1
    Hey skillUser,
    I looked into CDF -> Edit for the settting on finger and multiplier.
    Name|  Prompt                | Type  |  default value | display condition |
    finger |  Number of Finger | string |  1                  | t                        |
    m      |  Multiplier              | string |  1                  | deGetEditCellView()->cellViewType != "maskLayout"|
    The parameters look reasonable to me.  And I tried changing the name from "m" to "mult"; it doesn't seem to do anything.
    FYI, I tried changing Width and Length and they work.  Its just the finger/multiplier that are not working.
    Is there anything else I should look into?
  • skillUser
    Those are the parameter settings, you need to look at the Simulator Information section for your simulator to see how the parameters will be output.  Make sure that 'm' is on the list (since you show the 'm' parameter above, as opposed to, say, "mult").
    Hope it helps.
    regards,
    Lawrence.
