  3. Importing verilog to Cadence schematic
  • Replies 10
  • Subscribers 133
  • Views 24652
Wonyoung
Wonyoung over 14 years ago
I am trying to import a very simple verilog code containing one latch into Cadence using Import -> Verilog on CIW. I get the following error message.
INFO (VERILOGIN_GUI-13): Verilog Import process has started ...
ERROR (VERILOGIN-205): An internal memory error has occurred. Exiting.
INFO (VERILOGIN_GUI-15): Verilog Import completed. Look at logfile, ./verilogIn.log, for process execution details.
There is nothing in the logfile and I have enough memory. I am using IC6.1.5. Any help is appreciated!
Wonyoung
  • Quek
    Quek over 14 years ago
    Hi Wonyoung
    Would you please try the following and see if it helps?
    a. In "Import-Verilog" form, go to "Schematic Generation Options" tab
    b. Disable "Full Place and Route" option which is located at the bottom of the form
    If it does not help, please file a service request with your local Cadence support.
    Best regards
    Quek
  • Wonyoung
    Hi Quek,
    I just tried that but the problem is still there. Let me know if you have any other suggestions!
  • Quek
    Hi Wonyoung
    Would you please file a service request to your local Cadence support so that we can investigate this properly?
    Quek
  • Wonyoung
    Hi Quek,
    I will check with our university's IT people since they have the ID/password/license# required to login to the support site. Thanks!
    Wonyoung
  • Wonyoung
    Hi Quek,
    I just submitted a service request in the Cadence support website. Thanks!
  • Wonyoung
    At the same time, I am trying to see if using "verilog2oa" and "conn2sch" can import verilog to Cadence schematic using the following commands.
    verilog2oa -verilog "./myverilog.syn.v" -top "myverilog" -lib "test" -view "netlist" -tieHigh VDD -tieLow VSS -overwrite
    conn2sch -lib test -cell myverilog -view netlist -destlib test -destview schematic -verbose -param conn2sch.conf
    When I run conn2sch, it complains that "ERROR (CONN2SCH-193): Instance XXX is not bound to any master.". I was wondering if you have any recommendations on how to fix this, and if you think using verilog2oa and conn2sch could be an alternative to importing verilog in CIW. Thank you very much!
    Wonyoung
    I wouldn't recommend using verilog2oa - maybe you could use "ihdl" instead, but that's effectively the same command being used from the Import Verilog command.
  • Quek
    Hi Wonyoung
    Sorry that I cannot comment on "verilog2oa" because I don't use it myself. I do use the reverse cmd "oa2verilog" in my script and it works well. : )
    Best regards
    Quek
  • Wonyoung
    Hi all,
    I contacted customer support and they were very helpful in fixing the problem. There was a problem in my $path that was pointing to an old IC5 path instead of the IC6 that I was using. Thank you very much!
  • weebey
    weebey over 13 years ago
    I am having this same exact problem, but can't seem to fix it. Anyone have some thoughts? Thanks.
    I am running version IC6.1.5-64b-500.3
