  3. analog-mixed signal simulation with verilog-a vhdl and circuit...
  • Subscribers 133
  • Views 18113
analog-mixed signal simulation with verilog-a vhdl and circuit components
Zitty
Zitty over 14 years ago
 I´m working on a mixed signal circuit with several circuit compnents on transistor level and some digial compnents in vhdl. The latter will be transferred into a digital layout with standard cells.
 My hole test surrounding conatins components programmed in veriloga.
 To start I used also veriloga code for the digital components. So it was possible to use the normal spectre simulator.
Circuits with only transistorlevel components and vhdl components were simulated using the ams-simulator and that worked fine for me.But  I could not simulate circuits including the veriloga code this way.
Is there a possibility to simulate a circuit containing transistor level components, veriloa code and vhdl components? Or do I have to transfer all my veriloga components into vhdl? the problem is that mixed signal simulation takes quite long.
thanks
    You should be able to use veriloga models with AMS. When you say "I could not simulate circuts including the veriloga code this way", why not? Was there an error?
  • Zitty
     yes there was an error when i started simulation.
    i´ll explain you my simulationsetup shortly.
    1. create config file with vhdlinteg template.
    2. then use the config manager and go to plugins->ams then initialize ams simulation
    3. back at ade setup analyis and specify connection rules.
    4. start transient analysis.
    then i get message:
    Elaborating the design hierarchy:
    ncelab: *N,SFEDPL: Deploying new SFE in analog engine.
    ncelab: *W,CUNOUN: Cannot find any unit under ahdlLib.adc_8bit_ideal:symbol in the design libraries.
    ncelab: Memory Usage - 22.3M program + 672.4M data = 694.7M total
    ncelab: CPU Usage - 0.3s system + 2.8s user = 3.2s total (10.4s, 30.5% cpu)
    Failed to elaborate ("tests" "thermotest" "config1").
    In the hierarchy editor (is that what you mean by "config manager"?), do you have "veriloga" in the switch view list? Is it showing that the adc_8bit_ideal cell has "veriloga" as the view to use (in the cell or tree view)?
    Which versions are you using? (of both Virtuoso and the simulator) - although in practice  you've been able to do this since day 1 with AMS Designer...
  • Zitty
     yes i meant the hierachchy editor. and no i dit not have the verilog a switch on. i think that was the first problem.
    i´m using cadence virtuoso 6.1.5. how can i find out which version of the ams simulator i´m currently using?
     i´m getting another error message now, which was not shown before.
    it says:
    file: /soft64/Cadence/IUS_81U1/tools.lnx86/affirma_ams/etc/connect_lib/connectLib/R2E/module/verilog.vams
    ncvlog: *E,DLPAKW: Attempt to write module connectLib.R2E:module (VST) into a read-only library.
            errors: 1, warnings: 0
        Total errors/warnings found outside modules and primitives:
            errors: 0, warnings: 1
    ncvlog: Memory Usage - 11.1M program + 8.2M data = 19.2M total
    ncvlog: CPU Usage - 0.0s system + 0.0s user = 0.0s total (0.0s, 89.6% cpu)
    Failed to compile ('connectLib' 'R2E' 'module').
    Compilation failed.
    Successfully compiled: 0
    Failed to compile: 1
