  3. Finding/Changing hilight layers in IC6.1.5.500.9
  • Subscribers 133
  • Views 1499
Merfman
Merfman over 14 years ago
How does one find/change the hilight layers used in the various tools/browsers in 6.1 in the layer palette?
 As an example, I'd like the change the line width for the layers used in the Annotation browser to make
the  line width bold so it's easier to find with old eyes...
Thanks in advance!
Merf
  • skillUser
    skillUser over 14 years ago
    Hi Merf,
    If you use the CIW menu Tools -> Display Resource Manager and then press the Edit button in the Display Resource Tool Box you will open the Display Resouce Editor window/tool.  Change the "Application" to DRE and you will see the various packets defined.  I believe that the ones that are used are: hilite, hilite1-9, annotate, annotate1-9, halo1-20,  plus various marker*** packets. There may be others used, but mostly this should cover the highlight 'layers'.  To modify, select the packet on the left and use the sections on the right to change the appearance - then press Apply at the bottom left to see the changes in the tool windows.
    Hopefully this answers your question?
    Lawrence.
  • Merfman
     Hi Lawrence,
    Thanks, that's an approach I hadn't used but is very similar to how I'v approached this problem before... what I'd REALLY like to see is some place with a definitive answer for what browsers use which layers.  In the process I'm using, there must be 100 to 150 layers defined and I really don't have the time to search the layer palette, change the layer, then see if the highlight changed...
    There must be a better way, but thanks for the reply!  I'll keep searching and if I come up with something new I'll post it here...
    Merf
  • Merfman
    Please don't ask me to explain "why" as I have no clue yet, but I was able to find/change the hilite layers used in the Annotation Browser by:
    I looked at the defined techfiles in my library browser.  I then used the tool Technology File Manager to dump every defined library into a directory of dumped file.  Looking at the layer descriptions in the Annotation Browser I saw the layers were similarly named "hiliteX"   Grep was applied to all the files to look for "hilite" and I found hilite drawing5 defined in the avTech file.  A quick change of that layer in the DRM and I was able to visually verify the change.
     Again, there HAS to be a better way but maybe this will help someone find/change that layer that's bugging them... ;)
