  3. Is there a way to make Cadence point to the error?
  • Replies 7
  • Views 21558
tony4tony
tony4tony over 14 years ago
Hi All,
                I am completely new to Cadence and am just doing my second tutorial. So please forgive my ignorance. I am basically trying to make a inverter layout. I am getting error regarding
"Violated Rules.
1 M1R1 Minimum density  of MET1 area [%] = 30
1 M2R1 Minimum density  of MET2 area [%] = 30
1 M3R1 Minimum density  of MET3 area [%] = 30 "
                     I was told I could get rid of the error by  setting "no coverage" when I run DRC. But I would like to know what the error is and how to fix it. I tried googling and searcched some forums. But couldnt find any answer. Can somebody please help?
Many Thanks,
Tony
  • tony4tony
    If this is not the correct location for the post please put it under the correct forum.
    Tony
  • Quek
    Quek over 14 years ago
    Hi Tony
    This is the correct forum. Every layout must meet certain density requirement so that it can be properly fabricated by the foundry. E.g. if the total area of your cellview is 10um2 ("um2" means micro-metre square) and you only a single piece of M1 metal with area 1um2, then it means that your M1 density is 100% * 1/10 = 10% and hence your cell fails the requirement of 30%.
    Modern foundries use CMP (chemical mechanical polishing) processes to smoothen the surface of the wafers and if the density of each layer is not uniform, the polishing of the wafer would result in uneven wire thickness and hence changes the intended characteristics of the process.
    You can read more about this from any IC design layout textbooks. E.g.
    http://www.amazon.com/IC-Layout-Basics-Practical-Guide/dp/0071386254
    Best regards
    Quek
  • tony4tony
    Hi Quek,
                        Thank you very much for the help. That is very helpful information. Is there an easy way to highlight in the layout editor which are the metal connectors which have violated the rules? Or do I have to go through each metal and see their properties?
    Tony
  • Quek
    Hi Tony
    For density errors, there is no single metal shape that is causing the violation. The error is a results of all the shapes. Let's go through the following example:
    - You have 2 metal1 shapes in your layout.
    - 1st metal1 shape has area of 1um2
    - 2nd metal1 shape has area of 2um2
    - Total cell layout is 10um2
    - DRC density requirement is 50%
    Using the total area of the shapes, your current density can be calculated as (1+2)/10 * 100% = 30%. Hence density error is reported during drc check. You cannot say that it is shape1 or shape2 that is causing the error. The error is a results of insufficient total metal1 area for the entire cell.
    Best regards
    Quek
  • tony4tony
    Hi Quek,
                         Playing with the options I found I can find the metal (or component dimensions)  using Windows->Assistants->Property View.. But how do I calculate/find the total cell layout area? Is it by the normal area equation (length x breadth)? Or is there any option in the editor which tells what is the total area?
    Tony
  • Quek
    Hi Tony
    Total cell area means the rectangular bounding box created from all the objects in your cellview.There is no option which can display the bounding box.
    Best regards
    Quek
  • linbo
    linbo over 14 years ago
     Hi Tony,
    You also need to consider which cell in terms of how close you are to the top level chip/IP in terms of hierarchy.  It makes no sense to check density on a small cell.  Typically density is checked on higher level cells or very large cells in terms of area.  This is because density is considered over the entire die.  A tiny cell may meet density but when placed into the chip the areas around it might be sparse and so you'll have a density issue.
    Are you working on IP or the whole chip?  Which process are you using?
    Generally the older, larger geometry processes like .13 and above will have more forgiving density rules.  Smaller processes like 65nm, 40nm, and below have much more stringent requirements and include multi level metal proximity rules.
     If you're doing IP for an SOC then you'll need to take care with the edges of your IP where the abutting neighboring layouts are unknown.
    Also be aware that the bounding box of cells also includes/surrounds the entirety of the labels/txt displays and can give you false errors if texts "hang out" outside the edges of actual active layers at the edge of your cell.
    A good way to proceed is just visually check each metal layer over your entire layout and any large open areas, especially close to denser areas will have problems.
     Finally all the large fabs provide density filling routines within Assura and/or Calibre so that you do not have to do this by hand.  There's usually an elaborate suite of special "fill" metal layers, fill vias, and corollary blocking layers. Some fabs/processes (like Jazz) do the fill for you unless you request otherwise.  Before spending a lot of time carefully making your layout meet density it might be good to check to see what your fab requirements are, what/where on the filling routines, and how to use.
    Does this help?
