  3. Saving simulation data for later use by running AMS
  • Replies 7
  • Views 19881
RichardCh
RichardCh over 14 years ago
Is it possitble to save data for later use by running AMS ?
I know savetime can be used in spectre.
Richard.
    Andrew Beckett over 14 years ago +1
    Richard, That's exactly what the save/restart is for in AMS. In cdnshelp (make sure it's picking up the documentation from the INCISIV stream you're using - if not, use Edit->Settings->Library and add…
    AMS Designer has a save/restore capability - this is covered in the documentation (in fact this has existed longer than the equivalent functionality in spectre).
  • RichardCh
    Hello, Andrew
    Thanks for your reminder. What I really want is store transient data to some specific time.
    Nex time I can run simulation after that specific time and speed up startup time.
    In spectre, I can use savetime=5mS and savefile=5msec. Next time, I can start simulation
    from 5mS by using 5msec.
    Best Regards,
    Richard.
    Richard,
    In cdnshelp (make sure it's picking up the documentation from the INCISIV stream you're using - if not, use Edit->Settings->Library and add the path to the INCISIV111/doc dir, or make sure that you pick cdnshelp from the INCISIV111/tools/bin dir (for example)), expand Incisive Enterprise Simulator, and then expand Analog Mixed-Signal Simulation. Select Virtuoso AMS Designer Simulator User Guide, and then in the search enable "Selected items" and search for restart.
    Or just search for the word restart in <INCISIVrootDir>/doc/amssimug/amssimug.pdf
  • nnlt
    nnlt over 7 years ago in reply to Andrew Beckett
    hi, andrew
    it describes that The restart command is supported only for pure digital designs and must not be used for mixed-signal designs and The restart command is supported only for pure digital designs and must not be used for mixed-signal designs in the Virtuoso AMS Designer Simulator User Guide.
  • nnlt
    so it is supported only for pure digital design ,not supported for mixed signal design?
    thanks!
    best regards,
    nnlt.
  • nnlt
    Hi, Andrew
    I have save snapshot times, when I change the load current in the testbench, the current waveform is as same as before change after I restart the simulation in the ams.
    Best regards,
    nnlt.
    Andrew Beckett over 7 years ago in reply to nnlt
    Not sure what you're doing (posting onto the end of a 7 year old thread is against the Forum Guidelines though), but this should work. There are two (at least) Rapid Adoption Kits on this:
    • Process Based Save Restart (AXUM Flow)
    • Using AMS Save Restart with Explorer and xrun
    I'd start by looking at those, and if you still have a problem, please contact customer support so that we can understand why it isn't working in your environment.
    Kind Regards,
