  3. Unbound pin error from Assura LVS after P&R
  • Subscribers 137
  • Views 6676
bjbit
bjbit over 13 years ago
When I do Assura LVS on the layout I got from P&R Encounter, the "unbound pins" error appears in the report. As the attached picture shows, the net marked as green color in both schematic and layout looks matching well. But it seems LVS cannot specify the pin ports from the instance of the standard cell layout? Can I ignore this error and trust that schematic and layout actually match? Thanks in advance.
Best regard,
  • Quek
    Quek over 13 years ago
    Hi bjbit
    I think it is better to troubleshoot the error so that you can get lvs match. The error looks strange. Assura seems to be reporting. You should check the sdb and ldb netlists in the run directory to see why Assura is reporting pin errors.
    terminal>vldbToCdl design.sdb > design.sdb.ascii
    The above cmd will convert the binary netlist to ascii format.
    Best regards
    Quek
  • berndfi
    berndfi over 13 years ago
    Check if your layout pins are in the correct format
    to get properly recognized by your Assura LVS.
    If you exchange the data from Encounter to Virtuoso in GDSII
    format your pins are most likely only defined as labels over the
    interconnects. This may work for a LVS run on GSDII layout basis,
    but probably not for a LVS on the Virtuoso layout database.
    If this is the case you can try the utility ‘Create Pins From Labels’,
    to get the pins in the proper form.
    From the layout window ‘Tools -> Create Pins From Labels’.
    Bernd
  • bjbit
    Sorry guys I should have posted a update that I already figured this out. The encounter automatically adds net names on label layers, and Assura LVS treats them as pins, which caused pin mismatch. Thanks all the same. Best regards,
  • alperro
    alperro over 12 years ago
    Hi bjbit,
    I have encountered the same problem. How could you solve this back then?
    Regards.
