  3. Convert schematic to Verilog file
  • Replies 12
  • Views 36802
Myskill
Myskill over 13 years ago
 Hi All,
            could you please help how to get verilog file from schematic.
Rambabu
    Andrew Beckett over 8 years ago in reply to NovikovBoris +1
    Please read the forum guidelines - posting a very specific question in a 5 year old general thread is definitely against the guidelines. Assuming you're talking about the Verilog netlister in Virtuoso…
    Either Tools->NC Verilog (from the CIW), or  Launch->Simulation->NC Verilog (from a schematic).
  • Myskill
    Any shell command for generating verilog code from schematic hierarchically from top cell to bottom
     Set it up in the UI as described above, and then you can do:
    si -command netlist -batch pathToRunDirectory
  • Myskill
     I am following following procedure for creation oa2verilog
    Open a shell from the library manager using File->Open shell window. This shell will be initialized with the necessary environment variables for the next step.
    In the new shell use:
    oa2verilog -lib <name of library> -cell <name of cell> -view schematic -verilog <name of cell>.v -recursive
    Substitute the lib name and cell name for the specific cell to netlist.
    This is limited to a cell without hierarchy
     I want generate it for hierachy Could you please help on this.
    Rambabu
    I already explained how to do this with the Verilog netlister. oa2verilog is much lower level and does not support all of the complex control that the OSS Verilog netlister does. I would not recommend  you trying to use oa2verilog (it doesn't have the concept of switch and stop list, for example, nor does it support config views).
    And you can tell this by the very small amount of coverage of oa2verilog in the documentation (search in cdnshelp and you'll see what I mean).
  • nannasin28
    nannasin28 over 13 years ago
    BS170
  • Myskill
    Hi all,
    This might be the most comon problem/task for ASIC engineers. I need a script that will generate a top level module for 'n' verilog modules (in 'n' files)
    Say I have A.v & B.v. The script should generate a ABTop.v such that
    module ABTop(
    clk
    input clk;
    input (etc etc)
    output (etc etc)
    A A_i (
    .clk (clk)
    B B_i (
    .clk (clk)
    endmodule
    if there is any shell command for automation, please suggest me.
    Rambabu
    The Verilog netlister (using "si") can do this. This is covered in solution 1839821 . The quick executive summary is that you can put:
    vlogifCompatibilityMode = "4.0"
    in your .simrc (or .cdsinit if using Virtuoso). It will then create a single Verilog netlist (concatenated from the individual pieces that the verilog netlister normally produces).
  • Myskill
     Thank you Aandrew for your help
    Rambabu
