  3. Need workaround for duplicate veriloga module name issu...
  • Subscribers 132
  • Views 17636
Need workaround for duplicate veriloga module name issue
JKupanna
JKupanna over 12 years ago
For some reason I'm including the same model file twice in a spectre simulation. In that .scs file I have a ahdl_include statement that includes a varilog-a model. Now because I'm loading this file twice, It is throwing an error saying that
"A built-in or regular master with name xyz already exists, cannot create an alias master with same name"
 Is there a option similar to duplicate_subckt=warning for verilog-a model.
Jagadish
    Jagadish,
    Which version of spectre are you using? ("spectre -W" will tell you, or it's at the top of the output file that spectre produces).
    For me, I have a module called forum which I ahdl_include twice, and I get:
    Warning from spectre during circuit read-in.
        WARNING (SFE-2654): VerilogA module `forum' override primitive/(verilogA module) `forum'.
    That said, there is an option, duplicate_module which controls this. If set to error, it errors out. According to spectre -h options, error should be the default, but it appears to actually warn for me.
    This option was introduced in MMSIM12.1 ISR13 (the latest hotfix). Before that (as far as I can tell) it didn't tell you anything about duplicates.
    Maybe your module name is using a reserved name? Not sure...
  • JKupanna
    Thanks for your response Andrew.
    I'm using Spectre 11.1.0.581.isr18. I don't have the latest ISR installed at my end to try duplicate_module option.
    Actually, I'm running Spectre with +mts option. My setup looks something like this,
    input.scs
    include "a.scs"
    subckt A
    include "a.scs"
    ends A
    subckt B
    include "b.scs"
    ends B
    With this kind of setup, I'm getting the below error,
    ERROR (SFE-398): "/path/resistors.va 91: A built-in or regular master with name rf_va already exists, cannot create an alias master with the same name."
    If I comment the first line(ie: provide models at scope level) then the simulation runs fine. Well I can go ahead and keep the a.scs as global model and comment the scope level model and run the simulation. But I was wondering if there is a way to workaround the current error.
    Regards, Jagadish
