  3. simulating verilog and schematics in spectre
  • Subscribers 132
  • Views 16741
engrMunna
engrMunna over 12 years ago
 Hi
Version use: Virtuoso IC6.1.5-64b.500.6 MMSIM 7.2
 I am simulating a verilogA deisgn along with some schematics  in spectre through analog deisgn enviroment. When i run the simulation I get the folloiwing error:
Error found by spectre during AHDL read-in.
    ERROR (VACOMP-2125): "path/cellname/veriloga/veriloga.va", near line 53: segment error for symbol: rfin
    ERROR (VACOMP-1816): Exiting AHDL compilation.
Time for Elaboration: CPU = 111.982 ms, elapsed = 121.443 ms.
Time accumulated: CPU = 3.08353 s, elapsed = 3.29656 s.
Peak resident memory used = 156 Mbytes.
spectre terminated prematurely due to fatal error.
  • engrMunna
      Solved. It was an error in the code. not a syntax error probably thats why it compiled.
    And for the benefit of others: the problem was that "rfin" is a voltage input to the verilogA block. I used "rfin" in a trasnsition statement as: V(out) <+ transition(rfin, delay). this was wrong and thats why it gave the error. The correct way to do it is V(out) <+ transition(V(rfin),delay)
    where as rfin is deifned as an electrical type.
    Do you have spectre in your UNIX path and can it run? Try typing "spectre -W" from the UNIX command line that you're running virtuoso from and show what it reports.
    The "Read veriloga" bit is correct - this is how it should work.
    The netlisting error is unsurprising - if the checker doesn't run, it also can't extract the pins used in the VerilogA, and hence it doesn't
     Timing problem - didn't see your last append before I hit the Post button.
