  3. passing CDF parameters to verilog block in SpectreVerilog...
  • Views 18628
passing CDF parameters to verilog block in SpectreVerilog simulations
RomeshNandwana
RomeshNandwana over 12 years ago
I am trying to run a SpectreVerilog cosimulation with a simple analog and digital clock generator block. I am trying to pass some parameter values ("delay" for the clock generator ) to the verilog block. While it shows my parameters as CDF parameters on the symbol but it does not pass to the verilog code and uses the default value. Is there some easy way to pass the cdf parameter to this verilog block ???
Code for my verilog code is the following :
module clock(clk );
    output clk;
      reg  clk;
    parameter delay=10;
  initial     //initialize the clock
    begin
          clk = 0;
    end
always #delay clk<= ~clk;   // default clock  period = 20 time units
endmodule
  • skillUser
    skillUser over 12 years ago
    I think you might want to look at Solution Article 1844335 for an example of how to print CDF parameters in the Verilog netlist (as defparam statements).
    Hope this helps.
    Lawrence.
  • skillUser
    I just tested it, by the way, here's an example result after setting the instance CDF parameter to 15:
    // Library - testLib, Cell - clockTest, View - schematic
    // LAST TIME SAVED: May  8 15:51:59 2014
    // NETLIST TIME: May  8 15:52:09 2014
    `timescale 1ns / 1ns
    module clockTest (  );
    specify
        specparam CDS_LIBNAME  = "testLib";
        specparam CDS_CELLNAME = "clockTest";
        specparam CDS_VIEWNAME = "schematic";
    endspecify
    clock I0 ( net1);
    defparam
        I0.delay =  15;
    endmodule
  • RomeshNandwana
     Thanks skillUser,
    I tried it and it works fine for me too. I thought there might be a way similar to AMS simulations where the tool picks up the CDF parameters directly from the file and we dont need to do any manual edit.
    Unfortunately not. The Verilog netlister is a non-CDF based netlister. There are enhancement requests however to make this much more straightforward.
    That said, spectreVerilog is really obsolete and you should be using AMS instead.
  • RomeshNandwana
     Thanks for the information Andrew.
