  3. Convergence Issue with verilogA model
  • Views 18660
Flyyn Rider
Flyyn Rider over 11 years ago
 Hi, (some weird text appers below and i dont know what that is, my post starts with : I am sim......)
I am simulating 12 bit segmented SAR ADC with comparator in Verilog A. I have read several posts on achieving convergence like relaxing tolerances/specifying cmim etc. In a 12 bit ADC my LSB is around 250uV and I can’t afford to relax the tolerances further from their default values.
Problem:
Anyway the problem is not with my foundry model circuit instances, nothing wrong with the circuit netlist. I face convergence problems at the output of Verilog A comparator model. And I need to know how to fix the comparator code to avoid convergence issues. When I replace Verilog A comparator with transistor based design, no convergence problems are flagged.
But I have to run MC simulations and I don’t want to include the spread of comparator in my ADC accuracy plots for now, so it is crucial that I use Verilog model for comparator.
Although issues are flagged (error requirement were not satisfied because of convergence difficulties), for nominal run I don’t get convergence problem. But during MC simulations when a 200th simulation fails to converge, it translates to enormous wastage of time.
I have attached pdf presentation containing snapshots of my problem.
Fig 1 shows the entire circuit schematics
Fig 2 shows the comparator block and the node where convergence issue is reported
Fig 3 shows the Verilog code for comparator
Fig 4 and 5 show the snapshots of output log files which I have commented
So the problem is with the Verilog code of comparator. Can we change the Verilog code to achieve convergence? If yes then what should I change? If no then what should I do?
reporting convergence problem.pdf
    It may not definitely be the VerilogA model, but I would suggest changing the code to something like:
    real compOut=0;
    @cross(V(sigin)-V(sigref),0);
    if (V(sigin)<V(sigref) compOut=sigout_low;
    else compOut=sigout_high;
    V(sigout)<+transition(compOut,0,1n);
    Set an appropriate delay and transition on your output transition. Currently you have instantaneous change, which is not good for convergence. Also, I'm using @cross here to ensure that it solves for the crossing point - without this it won't accurately get the decision point (that may not matter to you).
    Note I didn't test the code above, so there may be typos...
  • Flyyn Rider
    Thanks Andrew
