  3. Using MMSIM11.1 (64 bit) to simulate VerilogA modules
  • Views 16985
qnehal
qnehal over 11 years ago
I am having problem trying to simulate my netlist that contains verilogA modules in MMSIM11.1 (64bit) whereas 32bit version of MMSIM11.1 works fine with the netlist. I am using IC6.1.5-64b.500.12 and spectre 11.1.0.509.isr14 . I will be very thankful for any comments and suggestions to help me solve this.
Best,
Qaiser.
Logfile is attached below.
Fullscreen Joblog.txt Download
\# Program start time UTC 2014.12.17 02:52:48.878
\# Local time Tuesday 16 December 2014, 6:52 pm
\o Program:		@(#)$CDS: virtuoso version 6.1.5 07/04/2012 06:58 (sjfdl055) $
\o Hierarchy:		/app/apps3/Cadence/IC615/tools.lnx86/dfII/
\o Sub version:		sub-version  IC6.1.5-64b.500.12  (64-bit addresses)
\# Host name (type):	icslsrv3.ee.ucla.edu (x86_64)
\# Operating system:	Linux 2.6.18-348.el5 #1 SMP Wed Nov 28 21:22:00 EST 2012
\# X display name (WxH):	icslsrv3.ee.ucla.edu:80.0 (1024x868)
\# Available geometry:			TL(0:0) BR(1023:867)
\# X server:			RealVNC Ltd (VNC nograph server)
\# Depth of Visual (Root):	16 (16)
\# Number of Planes Used:	16
\# X version:		11.0 (vendor release 3370)
\# X resource pool:	base 0x1000000, mask 0x3fffff (4194303), shift 0
\# 			current id 0x31, current max 0x3ffffa (4194298)
\# Memory report:	maximum data size 18446744073709551615 (0xffffffffffffffff) bytes
\# Memory report:	maximum process size 18446744073709551615 (0xffffffffffffffff) bytes
\# Initial sbrk value:	486313984 (0x1cfc9000) bytes
\# Available memory:	275519972 (0x106c19e4) kilobytes
\# System memory:	408598340 (0x185ab744) kilobytes
\# Maximum memory size:	418404700160 (0x616add1000) bytes
\# Max mem available:	282180505600 (0x41b344d000) bytes
\# Initial memory used:	48054272 (0x2dd4000) bytes
\# Qt version:		4.5.3
\# Window Manager:	other
\# User Name:		qnehal
\o Working Directory:	icslsrv3.ee.ucla.edu:/w/ee.00/abidi/qnehal/Cadence_TSMC/N28
\# Process Id:		18720
\o
\o COPYRIGHT � 1992-2012  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
\o           � 1992-2012  UNIX SYSTEMS Laboratories INC.,
\o                          Reproduced with permission.
\o
\o This Cadence Design Systems program and online documentation are
\o proprietary/confidential information and may be disclosed/used only
\o as authorized in a license agreement controlling such use and disclosure.
\o
\o           RESTRICTED RIGHTS NOTICE (SHORT FORM)
\o Use/reproduction/disclosure is subject to restriction
\o set forth at FAR 1252.227-19 or its equivalent.
\# Available memory:	275507580 (0x106be97c) kilobytes UTC 2014.12.17 02:52:49.441
\# Memory report: Maximum memory size now 282191785984 (0x41b3f0f000) bytes, UTC 2014.12.17 02:52:49.441
\o Loading geView.cxt
\o Loading menuBuilder.cxt
\o Loading schView.cxt
\o Loading selectSv.cxt
\o Loading LVS.cxt
\o Loading layerProc.cxt
\o Loading xlUI.cxt
\o Loading auCore.cxt
\o Loading vhdl.cxt
\o Loading seismic.cxt
\o Loading ci.cxt
\o Loading ams.cxt
\o Loading adexl.cxt
\o Loading oasis.cxt
\o Loading asimenv.cxt
\o Loading analog.cxt
\o Loading par.cxt
\o Loading socket.cxt
\o Loading alvs.cxt
\o *Info*    Exporting services from client ...
\o
\o END OF USER CUSTOMIZATION
\o *Info*    Client has finished starting ...
\o
\p >
\o
\o
\o *Info*    Configuring the session ...
\o
\o 	Library      = CELL28_TIA_Sec_Order
\o 	Cell         = tb_CLK_16PH_Weight_Recomb
\o 	View         = schematic
\o 	Simulator    = spectre
\o 	State Path   = $AXL_SETUPDB_DIR/test_states
\o 	State Name   = CELL28_TIA_Sec_Order:tb_CLK_16PH_Weight_Recomb:1_none_Interactive.6
\o 	Results DB   = /w/ee.00/abidi/qnehal/Cadence_TSMC/N28/CELL28_TIA_Sec_Order/tb_CLK_16PH_Weight_Recomb/adexl/results/data/Interactive.6.rdb
\o 	Results Dir  = /w/ee.00/abidi/qnehal/simulation/CELL28_TIA_Sec_Order/tb_CLK_16PH_Weight_Recomb/adexl/results/data/Interactive.6/1/CELL28_TIA_Sec_Order:tb_CLK_16PH_Weight_Recomb:1
\o 	Results Loc  = /w/ee.00/abidi/qnehal/simulation/CELL28_TIA_Sec_Order/tb_CLK_16PH_Weight_Recomb/adexl/results/data
\o 	Project Dir  = /u1/ee/qnehal/simulation
\o 	Setup DB loc = /w/ee.00/abidi/qnehal/Cadence_TSMC/N28/CELL28_TIA_Sec_Order/tb_CLK_16PH_Weight_Recomb/adexl
\o 	File Encoding = 0
\o
\o
\o Loading simui.cxt
\o Loading awv.cxt
\o Loading viva.cxt
\o *Info*    Spectre controlMode is set "batch".
\o
\o Loading spectrei.cxt
\o Loading relXpert.cxt
\o Initializing from libInit.il for library tsmcN28...
\o    --  tsmcLDEparamTable.il
\o    --  cniUtils_encrypted.il
\o    --  tsmcPdkParamTable.il
\o    --  py2il_loadcdn.il
\o    --  py2il.cdn
\# Memory report: now 695545856 (0x29753000) bytes, UTC 2014.12.17 02:53:05.809
\o    --  py2il_n28.cdn
\o    --  /w/ee.00/abidi/qnehal/TSMC28nmPDK/tsmcN28_6X/PDK/T-N28-CR-SP-010-W1/1d0_2p1a/tsmcN28/../skill/Patch/tsmcCRN28HPM_v1.0_2p1a_1.cxt
\o    --  tsmcSim_cdf_api.cxt
\o    --  tsmcN28Tool.cxt
\o    --  tsmcDNA_utility.cxt
\o    --  tsmc_LDE.cxt
\o    --  tsmcN28.cxt
\o    --  tsmcN28_gateCB.cxt
\o    --  tsmc_esti.ile
\o Loading hspiceD.cxt
\o Loading spectreinl.cxt
\o Loading msgHandler.cxt
\o Loading UltraSim.cxt
\o Loading AMSOSS.cxt
\o Loading AMS.cxt
\o Loading Working place Display File '/w/ee.00/abidi/qnehal/Cadence_TSMC/N28/display.drf'
\o WARNING (ADE-5033): Cannot find the environment variable 'sweeptype' for tool 'ams.hbsp'.
\o         Its internal default value will be used.
\o WARNING (ADE-5034): Unable to access the default environment variables in the simulator's
\o         global .cdsenv file ('<your_install_dir>/tools/dfII/etc/tools/ams/.cdsenv')
\o         because the file is missing or out-of-date. Till this problem exists, internal
\o         default values will be used for these environment variables during this session.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.hbsp'.
\o WARNING (ADE-5033): Cannot find the environment variable 'noisetypeUI' for tool 'ams.hbnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'MultiEna' for tool 'ams.hbnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.hbnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sbsm' for tool 'ams.hbnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'inType' for tool 'ams.hbnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'refsbSelect' for tool 'ams.hbnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'outType' for tool 'ams.hbnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'donoise' for tool 'ams.hbnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'special' for tool 'ams.hbac'.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.hbac'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sbsm' for tool 'ams.hbac'.
\o WARNING (ADE-5033): Cannot find the environment variable 'tones' for tool 'ams.hb'.
\o WARNING (ADE-5033): Cannot find the environment variable 'oscana' for tool 'ams.hb'.
\o WARNING (ADE-5033): Cannot find the environment variable 'HBTonesNum' for tool 'ams.hb'.
\o WARNING (ADE-5033): Cannot find the environment variable 'harmonicsCyc' for tool 'ams.hb'.
\o WARNING (ADE-5033): Cannot find the environment variable 'harmonics' for tool 'ams.hb'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sigpartB' for tool 'ams.hb'.
\o WARNING (ADE-5033): Cannot find the environment variable 'hbhomotopy' for tool 'ams.hb'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweepB' for tool 'ams.hb'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweep' for tool 'ams.hb'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweep2' for tool 'ams.hb'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweep3' for tool 'ams.hb'.
\o WARNING (ADE-5033): Cannot find the environment variable 'loadpullB' for tool 'ams.hb'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweeptype' for tool 'ams.qpsp'.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.qpsp'.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.qpxf'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sbsm' for tool 'ams.qpxf'.
\o WARNING (ADE-5033): Cannot find the environment variable 'outType' for tool 'ams.qpxf'.
\o WARNING (ADE-5033): Cannot find the environment variable 'MultiEna' for tool 'ams.qpnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.qpnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sbsm' for tool 'ams.qpnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'inType' for tool 'ams.qpnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'refsbSelect' for tool 'ams.qpnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'outType' for tool 'ams.qpnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.qpac'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sbsm' for tool 'ams.qpac'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweeptype' for tool 'ams.psp'.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.psp'.
\o WARNING (ADE-5033): Cannot find the environment variable 'special' for tool 'ams.pxf'.
\o WARNING (ADE-5033): Cannot find the environment variable 'outType' for tool 'ams.pxf'.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.pxf'.
\o WARNING (ADE-5033): Cannot find the environment variable 'harmonics' for tool 'ams.pxf'.
\o WARNING (ADE-5033): Cannot find the environment variable 'noisetypeUI' for tool 'ams.pnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'MultiEna' for tool 'ams.pnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.pnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'harmonics' for tool 'ams.pnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'pnoisemethod' for tool 'ams.pnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'inType' for tool 'ams.pnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'refsbSelect' for tool 'ams.pnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'outType' for tool 'ams.pnoise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.pstb'.
\o WARNING (ADE-5033): Cannot find the environment variable 'special' for tool 'ams.pac'.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.pac'.
\o WARNING (ADE-5033): Cannot find the environment variable 'harmonics' for tool 'ams.pac'.
\o WARNING (ADE-5033): Cannot find the environment variable 'engine' for tool 'ams.pss'.
\o WARNING (ADE-5033): Cannot find the environment variable 'harmonics' for tool 'ams.pss'.
\o WARNING (ADE-5033): Cannot find the environment variable 'hbhomotopy' for tool 'ams.pss'.
\o WARNING (ADE-5033): Cannot find the environment variable 'oscana' for tool 'ams.pss'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweepB' for tool 'ams.pss'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweep' for tool 'ams.pss'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweep2' for tool 'ams.pss'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweep3' for tool 'ams.pss'.
\o WARNING (ADE-5033): Cannot find the environment variable 'loadpullB' for tool 'ams.pss'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweep' for tool 'ams.sp'.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.sp'.
\o WARNING (ADE-5033): Cannot find the environment variable 'donoise' for tool 'ams.sp'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweep' for tool 'ams.xf'.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.xf'.
\o WARNING (ADE-5033): Cannot find the environment variable 'outType' for tool 'ams.xf'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweep' for tool 'ams.noise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.noise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'outType' for tool 'ams.noise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'inType' for tool 'ams.noise'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweep' for tool 'ams.dc'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweep' for tool 'ams.stb'.
\o WARNING (ADE-5033): Cannot find the environment variable 'rangeType' for tool 'ams.stb'.
\o WARNING (ADE-5033): Cannot find the environment variable 'outType' for tool 'ams.dcmatch'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweep' for tool 'ams.dcmatch'.
\o WARNING (ADE-5033): Cannot find the environment variable 'outType' for tool 'ams.pz'.
\o WARNING (ADE-5033): Cannot find the environment variable 'inType' for tool 'ams.pz'.
\o WARNING (ADE-5033): Cannot find the environment variable 'sweep' for tool 'ams.pz'.
\o Loading devCheck.cxt
\o
\o
\o
\o
\o
\o *Info*    Run start for Point ID (0 1) on testbench [
\o           CELL28_TIA_Sec_Order:tb_CLK_16PH_Weight_Recomb:1 ].
\o
\o Resetting statistical vars
\o
\o *Info*    Setting parameter values ...
\o
\o Setting var Acmfb = "100"
\o Setting var Cf = "8p"
\o Setting var Ci = "50p"
\o Setting var Cout = "0"
\o Setting var Gm_TIA = "12.5m"
\o Setting var Gm_cmfb = "4m"
\o Setting var M = "16"
\o Setting var Rcm = "1M"
\o Setting var Rf = "10k"
\o Setting var Rout = "0"
\o Setting var Rswmain = "45"
\o Setting var Vg_MIX_bias = "0"
\o Setting var flo = "400M"
\o Setting var gamma = "1"
\o Setting temp(T) = 27
\o Setting var tf = "250e-15"
\o Setting var tr = "250e-15"
\o
\o *Info*    Netlist Directory =
\o           /w/ee.00/abidi/qnehal/simulation/CELL28_TIA_Sec_Order/tb_CLK_16PH_Weight_Recomb/adexl/results/data/Interactive.6/1/CELL28_TIA_Sec_Order:tb_CLK_16PH_Weight_Recomb:1/netlist
\o
\o
\o *Info*    Data Directory    =
\o
\o
\o *Info*    Creating Netlist for Point ID (0 1)
\o
\o generate netlist...
\o Loading seCore.cxt
\o Begin Incremental Netlisting Dec 16 18:53:09 2014
\o End netlisting Dec 16 18:53:09 2014
\o
\o 	The netlist is up to date.
\o 	Time taken to compare the design with netlist:   0.0s
\o       ...successful.
\o compose simulator input file...
\o       ...successful.
\o
\o *Info*    Running simulation on testbench [
\o           CELL28_TIA_Sec_Order:tb_CLK_16PH_Weight_Recomb:1 ] for
\o           Point ID (0 1).
\o
\o Delete psf data in /w/ee.00/abidi/qnehal/simulation/CELL28_TIA_Sec_Order/tb_CLK_16PH_Weight_Recomb/adexl/results/data/Interactive.6/1/CELL28_TIA_Sec_Order:tb_CLK_16PH_Weight_Recomb:1/psf.
\o       ...successful.
\o start simulator if needed...
\o       ...successful.
\o simulate...
\o To view the simulator output, right-click on the test name, result
\o name, or any value in the "Results" tab of the Outputs section and
\o choose "Output Log" menu option.
\o Loading paraplot.cxt
\o INFO (ADE-3067): Errors encountered during simulation. For more information, right-click
\o         on a test name in the 'Results' tab of the Outputs pane and choose 'Output Log'
\o         to view the simulation run log.
\o
\o *Error*   Error ID  = 5011
\o *Error*   Error Msg = Simulator failed to complete the simulation.
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o Begin Incremental Netlisting Dec 16 18:53:23 2014
\o End netlisting Dec 16 18:53:23 2014
\o
\o       ...successful.
\o       ...successful.
\o
\o           Point ID (0 1).
\o
\o       ...successful.
\o       ...successful.
\o simulate...
\o
\o
\o
\o
\o
\o
\o Simulation design variables differ from those on the cellView,
\o they have been saved in the file "/tmp/saved-design-variables2".
\o To save future changes, copy variables to cellView before exiting.
\o
\o
\o
\o 	View         = schematic
\o 	State Name   = CELL28_TIA_Sec_Order:tb_CLK_16PH_Weight_Recomb:1_none_Interactive.7
\o 	Results DB   = /w/ee.00/abidi/qnehal/Cadence_TSMC/N28/CELL28_TIA_Sec_Order/tb_CLK_16PH_Weight_Recomb/adexl/results/data/Interactive.7.rdb
\o 	Results Dir  = /w/ee.00/abidi/qnehal/simulation/CELL28_TIA_Sec_Order/tb_CLK_16PH_Weight_Recomb/adexl/results/data/Interactive.7/1/CELL28_TIA_Sec_Order:tb_CLK_16PH_Weight_Recomb:1
\o
\o
\o
\o
\o
\o
\o
\o
\o *Info*    Run start for Point ID (1 1) on testbench [
\o
\o
\o
\o Setting var Rout = "1"
\o
\o           /w/ee.00/abidi/qnehal/simulation/CELL28_TIA_Sec_Order/tb_CLK_16PH_Weight_Recomb/adexl/results/data/Interactive.7/1/CELL28_TIA_Sec_Order:tb_CLK_16PH_Weight_Recomb:1/netlist
\o
\o
\o
\o
\o *Info*    Creating Netlist for Point ID (1 1)
\o
\o Begin Incremental Netlisting Dec 16 18:54:59 2014
\o End netlisting Dec 16 18:54:59 2014
\o
\o       ...successful.
\o       ...successful.
\o
\o           Point ID (1 1).
\o
\o Delete psf data in /w/ee.00/abidi/qnehal/simulation/CELL28_TIA_Sec_Order/tb_CLK_16PH_Weight_Recomb/adexl/results/data/Interactive.7/1/CELL28_TIA_Sec_Order:tb_CLK_16PH_Weight_Recomb:1/psf.
\o       ...successful.
\o       ...successful.
\o simulate...
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o Begin Incremental Netlisting Dec 16 18:55:03 2014
\o End netlisting Dec 16 18:55:03 2014
\o
\o       ...successful.
\o       ...successful.
\o
\o           Point ID (1 1).
\o
\o       ...successful.
\o       ...successful.
\o simulate...
\o
\o
\o
\o
\o
\o
\# Memory report: Maximum memory size now 271717994496 (0x3f43a79000) bytes, UTC 2014.12.17 02:58:10.210
\o
\o
\o
\o 	View         = schematic
\o 	State Name   = CELL28_TIA_Sec_Order:tb_CLK_16PH_Weight_Recomb:1_none_Interactive.8
\o 	Results DB   = /w/ee.00/abidi/qnehal/Cadence_TSMC/N28/CELL28_TIA_Sec_Order/tb_CLK_16PH_Weight_Recomb/adexl/results/data/Interactive.8.rdb
\o 	Results Dir  = /w/ee.00/abidi/qnehal/simulation/CELL28_TIA_Sec_Order/tb_CLK_16PH_Weight_Recomb/adexl/results/data/Interactive.8/1/CELL28_TIA_Sec_Order:tb_CLK_16PH_Weight_Recomb:1
\o
\o
\o
\o
\o
\o
\o
\o
\o *Info*    Run start for Point ID (2 1) on testbench [
\o
\o
\o
\o
\o           /w/ee.00/abidi/qnehal/simulation/CELL28_TIA_Sec_Order/tb_CLK_16PH_Weight_Recomb/adexl/results/data/Interactive.8/1/CELL28_TIA_Sec_Order:tb_CLK_16PH_Weight_Recomb:1/netlist
\o
\o
\o
\o
\o *Info*    Creating Netlist for Point ID (2 1)
\o
\o Begin Incremental Netlisting Dec 16 18:59:02 2014
\o End netlisting Dec 16 18:59:02 2014
\o
\o       ...successful.
\o       ...successful.
\o
\o           Point ID (2 1).
\o
\o Delete psf data in /w/ee.00/abidi/qnehal/simulation/CELL28_TIA_Sec_Order/tb_CLK_16PH_Weight_Recomb/adexl/results/data/Interactive.8/1/CELL28_TIA_Sec_Order:tb_CLK_16PH_Weight_Recomb:1/psf.
\o       ...successful.
\o       ...successful.
\o simulate...
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o Begin Incremental Netlisting Dec 16 18:59:15 2014
\o End netlisting Dec 16 18:59:15 2014
\o
\o       ...successful.
\o       ...successful.
\o
\o           Point ID (2 1).
\o
\o       ...successful.
\o       ...successful.
\o simulate...
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o 	View         = schematic
\o
\o
\o
\o
\o
\o
\o
\o
\o *Info*    Run start for Point ID (3 1) on testbench [
\o
\o
\o
\o
\o
\o
\o
\o
\o *Info*    Creating Netlist for Point ID (3 1)
\o
\o Begin Incremental Netlisting Dec 16 19:00:11 2014
\o End netlisting Dec 16 19:00:11 2014
\o
\o       ...successful.
\o       ...successful.
\o
\o           Point ID (3 1).
\o
\o       ...successful.
\o       ...successful.
\o simulate...
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o Begin Incremental Netlisting Dec 16 19:00:18 2014
\o End netlisting Dec 16 19:00:18 2014
\o
\o       ...successful.
\o       ...successful.
\o
\o           Point ID (3 1).
\o
\o       ...successful.
\o       ...successful.
\o simulate...
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o 	View         = schematic
\o
\o
\o
\o
\o
\o
\o
\o
\o *Info*    Run start for Point ID (4 1) on testbench [
\o
\o
\o
\o
\o
\o
\o
\o
\o *Info*    Creating Netlist for Point ID (4 1)
\o
\o Begin Incremental Netlisting Dec 16 19:01:12 2014
\o End netlisting Dec 16 19:01:13 2014
\o
\o 	Time taken to compare the design with netlist:   1.0s
\o       ...successful.
\o       ...successful.
\o
\o           Point ID (4 1).
\o
\o       ...successful.
\o       ...successful.
\o simulate...
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o
\o Begin Incremental Netlisting Dec 16 19:01:20 2014
\o End netlisting Dec 16 19:01:21 2014
\o
\o       ...successful.
\o       ...successful.
\o
\o           Point ID (4 1).
\o
\o       ...successful.
\o       ...successful.
\o simulate...
\o
\o
\o
\o
\o
\o
\o
\o *Info*    Received signal SIGTERM.
\o
\o
    Qaiser,
    The log file you sent is the ADE XL job log file, and doesn't give much info. It would be more useful to see the simulator log file.
  • qnehal
    Sorry my mistake, the simulator log file is attached below.
    Fullscreen outputlog.txt Download
    Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
    Version 11.1.0.509.isr14 64bit -- 14 Aug 2012
    Copyright (C) 1989-2012 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
    Protected by U.S. Patents:
            5,610,847; 5,790,436; 5,812,431; 5,859,785; 5,949,992; 5,987,238;
            6,088,523; 6,101,323; 6,151,698; 6,181,754; 6,260,176; 6,278,964;
            6,349,272; 6,374,390; 6,493,849; 6,504,885; 6,618,837; 6,636,839;
            6,778,025; 6,832,358; 6,851,097; 6,928,626; 7,024,652; 7,035,782;
            7,085,700; 7,143,021; 7,493,240; 7,571,401.
    Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
    User: qnehal   Host: icslsrv3.ee.ucla.edu   HostID: 43A48BC2   PID: 21797
    Memory  available: 121.0790 GB  physical: 270.5638 GB
    CPU Type:        Intel(R) Xeon(R) CPU E5-2667 0 @ 2.90GHz
              Processor PhysicalID CoreID Frequency
                  0         0        0     2900.1
                  1         1        0     2900.1
                  2         0        1     2900.1
                  3         1        1     2900.1
                  4         0        2     2900.1
                  5         1        2     2900.1
                  6         0        3     2900.1
                  7         1        3     2900.1
                  8         0        4     2900.1
                  9         1        4     2900.1
                 10         0        5     2900.1
                 11         1        5     2900.1
                 12         0        0     2900.1
                 13         1        0     2900.1
                 14         0        1     2900.1
                 15         1        1     2900.1
                 16         0        2     2900.1
                 17         1        2     2900.1
                 18         0        3     2900.1
                 19         1        3     2900.1
                 20         0        4     2900.1
                 21         1        4     2900.1
                 22         0        5     2900.1
                 23         1        5     2900.1
    Simulating `input.scs' on icslsrv3.ee.ucla.edu at 7:01:22 PM, Tue Dec 16, 2014 (process id: 21797).
    Current working directory: /w/ee.00/abidi/qnehal/simulation/CELL28_TIA_Sec_Order/tb_CLK_16PH_Weight_Recomb/adexl/results/data/Interactive.6/1/CELL28_TIA_Sec_Order:tb_CLK_16PH_Weight_Recomb:1/netlist.
    Command line:
        /w/apps3/Cadence/MMSIM111/tools.lnx86/spectre/bin/64bit/spectre  \
            input.scs +escchars +log ../psf/spectre.out -format psfxl -raw  \
            ../psf +lqtimeout 900 -maxw 5 -maxn 5 +error +info
    Loading /w/apps3/Cadence/MMSIM111/tools.lnx86/cmi/lib/64bit/5.0/libinfineon_sh.so ...
    Loading /w/apps3/Cadence/MMSIM111/tools.lnx86/cmi/lib/64bit/5.0/libphilips_sh.so ...
    Loading /w/apps3/Cadence/MMSIM111/tools.lnx86/cmi/lib/64bit/5.0/libsparam_sh.so ...
    Loading /w/apps3/Cadence/MMSIM111/tools.lnx86/cmi/lib/64bit/5.0/libstmodels_sh.so ...
    Time for NDB Parsing: CPU = 1.38379 s, elapsed = 1.53579 s.
    Time accumulated: CPU = 1.38379 s, elapsed = 1.53579 s.
    Peak resident memory used = 60.1 Mbytes.
    Created directory input.ahdlSimDB/ (775)
    Created directory input.ahdlSimDB//3287_N28_MyVerilogA_QN_CLK_16PH_Weight_Recomb_veriloga_veriloga.va.CLK_16PH_Weight_Recomb.ahdlcmi/ (775)
    Created directory input.ahdlSimDB//3287_N28_MyVerilogA_QN_CLK_16PH_Weight_Recomb_veriloga_veriloga.va.CLK_16PH_Weight_Recomb.ahdlcmi/Linux-64/ (775)
    Compiling ahdlcmi module library.
    Finished compilation in 1.12 s (elapsed).
    Installed compiled interface for CLK_16PH_Weight_Recomb.
    Opening directory input.ahdlSimDB/ (775)
    Created directory input.ahdlSimDB//4249_artist_ahdlLib_adder_veriloga_veriloga.va.adder.ahdlcmi/ (775)
    Created directory input.ahdlSimDB//4249_artist_ahdlLib_adder_veriloga_veriloga.va.adder.ahdlcmi/Linux-64/ (775)
    Finished compilation in 937 ms (elapsed).
    Installed compiled interface for adder.
    Time for Elaboration: CPU = 144.978 ms, elapsed = 2.34398 s.
    Time accumulated: CPU = 1.52877 s, elapsed = 3.88004 s.
    Peak resident memory used = 69.4 Mbytes.
    Time for EDB Visiting: CPU = 7.999 ms, elapsed = 15.5561 ms.
    Time accumulated: CPU = 1.53676 s, elapsed = 3.8959 s.
    Peak resident memory used = 69.6 Mbytes.
    There doesn't appear to be any error in the log file, but it does appear to stop rather abruptly. It suggests that maybe spectre is exiting abnormally (with a crash, maybe). Perhaps if you go into the netlist directory and try running the "runSimulation" script (if you're running from ADE XL, you should be able to open a terminal using the right mouse button menu over the point, to get you to the right place). Maybe it will print more messages in the terminal window which you can post here?
  • qnehal
    Thanks Andrew. I did what you recommended and the output is given below.
    Best,
    Qaiser
    Simulating `input.scs' on icslsrv3.ee.ucla.edu at 1:04:15 PM, Wed Dec 17, 2014
            (process id: 14385).
    Time for NDB Parsing: CPU = 1.90371 s, elapsed = 4.66243 s.
    Time accumulated: CPU = 1.90371 s, elapsed = 4.66243 s.
    Peak resident memory used = 59.2 Mbytes.
    Existing shared object for module CLK_16PH_Weight_Recomb is up to date.
    Existing shared object for module adder is up to date.
    Time for Elaboration: CPU = 53.992 ms, elapsed = 125.25 ms.
    Time accumulated: CPU = 1.9577 s, elapsed = 4.78785 s.
    Peak resident memory used = 64.9 Mbytes.
    Time for EDB Visiting: CPU = 6 ms, elapsed = 26.6252 ms.
    Time accumulated: CPU = 1.9647 s, elapsed = 4.81478 s.
    Peak resident memory used = 65.2 Mbytes.
    /w/apps3/Cadence/MMSIM111/tools/bin/spectre[544]: wait: 14385: Abort
    Sounds like a bug. So first I'd suggest checking with the latest hotfix of either MMSIM13.1 or MMSIM14.1 to see if it still happens, and if it does, please contact customer support.
