  3. GPDK045
  • Subscribers 136
  • Views 19711
GPDK045
analogy
analogy over 11 years ago
Lets say I want to perform EM simulation using an EM simulator on ind_a/ind_s (by exporting GDS of inductor).Layer mapping is not a problem, but what about substrate file ?
  • Quek
    Quek over 11 years ago
    Hi GPDK045
    I think you will need to provide more information in order to full understand the question. E.g.
    - What kind of PDK are you using? Is GPDK045 just your user name or are you really using Cadence generic 45nm pdk?
    - What is the EM simulator which you are using?
    - What is the purpose of the substrate file? Is the substrate file a part of the EM simulator setup or are you referring to the substrate file for Quantus substrate exraction?
    Best regards
    Quek
  • analogy
    Yes, I'm using gpdk045 (generic 45 mm pdk from cadence). I will be gds of ind_a inductor in ADS momentum for EM field simulation.For this I need .slm (substrate file). The question here is, if I don't have substrate file for gpdk045 and I have to create one in ADS momentum , what kind of substrate is suitable for gpdk045 devices ?
  • Quek
    Hi analogy
    gpdk045 is for practice purposes so it is ok to define any substrate which suits your purpose (e.g. a simple p-substrate with thickness XYZ um).
    Best regards
    Quek
  • mohd gufran
    mohd gufran over 6 years ago in reply to Quek
    can u provide me  the library
    Andrew Beckett over 6 years ago in reply to mohd gufran
    What library? Please read the forum guidelines (several of the bullets - posting on old threads, posting more than once for the same question) not providing a clear question, using instant messaging shorthand).
