  3. making via come as double via by default
  • Views 16326
imaneet
imaneet over 11 years ago
how can i make the via come as double via by default? every time i create a via, i always need to edit the gui and change the column/row to make it double via.
any help is appreciated. thanks.
  • imaneet
    i have not figure out how to make the via come as double contact by default but i just created a bindket to make it double via. here's my solution, please comment if you want to improve.
    hiSetBindKey("Layout" "<Key>F10" "setof(obj geGetSelSet() obj~>objType==\"stdVia\")~>cutColumns=2")
  • ColinSutlieff
    ColinSutlieff over 11 years ago
    there are several ways depending on which tool you are using.
    I will assume you are using the create via command in VLS-L.
    When you first use the create via command, click <F3> to bring up the create via properties form.
    Set the parameters that you want and then click on the save button (diskette icon in the middle of the form).
    This will create a so-called "via variant" and it will appear in the list of available vias.
    The next time you create a via, simply use this new via variant.
    If you are using VLS-XL you can create a constraint group and define a min num cut rule. The tools (Wire Editor included) will, by default, create a double (or however many cuts you want) via. More details can be found in the documentation for XL.
    Hope this helps.
    Colin
  • imaneet
    Thanks Colin, that helps as well. I usually use auto contact so it will fill the via depending on the metal overlap but in some cases like minimum wire width, it will bring up single via that's why I've asked if it's possible to make the via default as double via.
