  3. [Solved] MIM capacitor is not being recognized during L...
  • Views 19651
[Solved] MIM capacitor is not being recognized during LVS
Subrata
Subrata over 10 years ago
I'm trying to layout a MIM capacitor wiith MT bottom plate, and AM top plate in IBM's 7RF 180nm process. Going through the design manuals, I've found the correct ways (including floating plates and/or tie downs) to connect the MIM cap to intended contacts and pins. Everything looks clean through DRC, however, LVS doesn't seem to recognize the capacitor at all.The cap is being generated using the foundry's pcell and has label on it.
I'm using IC616 and ASSURA41. If anyone has some advice, it'd be really helpful.
Thanks.
  • Quek
    Quek over 10 years ago
    Hi Subrata
    The LVS deck should usually be able to extract the device if it is a pcell. This seems to be a case of mismatch between PDK and rule deck. It would be best to check with the foundry support.
    If Assura is completely unable to recognize the cap, it simply means that the mimcap recognition layer is not even being created. If the recognition layer is created but the cap is still not being used, you will get a malformed device error. But if you do not have any malformed device error, it means that no mimcap recognition layer has been detected. While it is possible for you to debug the LVS layers with the help of the VLW, I think it is not really necessary. It is best to just check with the foundry. : )
    Best regards
    Quek
  • Subrata
    Hi Quek,
    Thank you so much for your response. It was indeed a problem with the rule deck. I was laying out the cap using 6 layers of metal while checking with extract rule for 7 layers. Guess I should have figured that out during DRC.
    Thank you again and have a great day.
  • Quek
    Hi Subrata
    It is good to know that you have resolved the problem. Wrong LVS switches is indeed a common source of such issues.
    Best regards
    Quek
