  3. Problems generating layout
  • Subscribers 133
  • Views 20621
rafaelon
rafaelon over 10 years ago
I am using Virtuoso sub-version  IC6.1.5.500.16.2. I have problems when I generate a layout from a schematic. In the layout, the cells appear: pcell Eval Failed.
CIW description is the following:
INFO (LX-1063): Building the layout generation form...
*WARNING* (LX-2002): Cannot create layout instance for schematic instance 'V0' because there is no layout master defined.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|M3' because the instance master 'PRIMLIB_2113/ne3/layout' does not have a corresponding terminal 'B'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|M3' because the instance master 'PRIMLIB_2113/ne3/layout' does not have a corresponding terminal 'D'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|M3' because the instance master 'PRIMLIB_2113/ne3/layout' does not have a corresponding terminal 'G'.
*WARNING* (LX-2003): Cannot create instance terminal on layout instance '|M3' because the instance master 'PRIMLIB_2113/ne3/layout' does not have a corresponding terminal 'S'.
*WARNING* (LX-2006): There were errors or warnings during layout generation.
INFO (LX-1030): Run Connectivity - Check - Against Source for more details.
INFO (LCE-1006): Cellview 'PRIMLIB_2113/pe3/layout' is extracted using technology library 'TECH_XC018_2113' from the top level cellview and not its attached technology library 'cdsDefTechLib'.
INFO (LCE-1006): Cellview 'PRIMLIB_2113/ne3/layout' is extracted using technology library 'TECH_XC018_2113' from the top level cellview and not its attached technology library 'cdsDefTechLib'.
INFO (LCE-1009): The cell verifier found no violations.
Rafael,
    Something is a bit fishy with the attached technology library messages - it suggests that you have a library in the layout design which hasn't been attached to the right technology library. You can check that by going over the library name in the library manager and doing Right Mouse->Properties and seeing if techLibName is set - if you you can use Tools->Technology File Manager and attaching.
    Not sure if that's the real problem though.
    You probably need to contact the PDK provider to determine the PCell Eval Fail problem - nothing you listed above describes those errors.
    You can find  out more by using Verify->Marker->Explain and then clicking on the instance with the problem.
  • rafaelon
    Hi Andrew, Thank. I contacted the PDK provider. He recommended me recreate the PDK. Now it is working very well. Regards, Rafael.
  • monkeydliren
    monkeydliren over 7 years ago in reply to Andrew Beckett
    Hi Andrew, thanks for pointing out this useful tool.
    I am not sure what happened with rafaelon, but i got a similar error in layout xl as well when generating all from source, my issue was i included parameters in transistor width, which the layout editor cannot interpret, after i changed those parameters to the actual number, everything is working fine.
    Hopefully this can be helpful for anyone that might have some similar issue in the future
