  3. Solved: binary counter in VerilogA with programmable st...
  • Views 28208
Solved: binary counter in VerilogA with programmable stepsize
Clidre
Clidre over 10 years ago
I'm modeling a binary counter in VerilogA. I defined parameter stepsize that is the desired increment.
Below the code: it has 4 bits and stepsize=3.
I expected 0000 -> 0011 -> 0110 -> 1001 ...  BUT I get  0000 -> 0010 -> 0101 -> 1000...
So, I got only the first increment=2 making all the following outputs wrong. Do you see what I'm doing wrong in the code? Thanks!!!
`include "constants.vams"
`include "disciplines.vams"
`define SIZE 4
module counter (out, clk);
inout clk;
electrical clk;
output [`SIZE-1 :0] out;
electrical [`SIZE-1 :0] out;
parameter integer setval = 0 from [0:(1<<`SIZE)-1];
parameter real vtrans_clk = 0.6;
parameter real vtol = 0; // signal tolerance on the clk
parameter real ttol = 0; // time tolerance on the clk
parameter real vhigh = 1.2;
parameter real vlow = 0;
parameter real tdel = 30p;
parameter real trise = 30p;
parameter real tfall = 30p;
parameter integer up = 0 from [0:1]; //0=increasing 1=decreasing
parameter integer stepsize = 3;
integer outval;
analog begin
@(initial_step("static","ac")) outval = setval;
@(cross(V(clk)-vtrans_clk,1,vtol,ttol))
outval = (outval +(+up- !up)*stepsize)%(1<<`SIZE);
generate j (`SIZE-1 , 0) begin
V(out[j]) <+ transition (!!(outval &(1<<j))*vhigh+!(outval&(1<<j))*vlow,tdel,trise,tfall);
end
end
endmodule
  • Clidre
    Update:
    It works perfectly now. I post here the solution, hoping it can be helpful for future readers. The last command had a syntax error. I added a bracket between the two !! and it works now. The correct line is:
    V(out[j]) <+ transition (!(!(outval &(1<<j)))*vhigh+!(outval&(1<<j))*vlow,tdel,trise,tfall);
    Regards
  • vijaykpd
    vijaykpd over 8 years ago
    Its awesome!!
    Works well for me. Thank you very much for sharing the code.
    I would like to add enable input signal to the counter. So whenever the enable is greater than threshold, the count up/down should go on otherwise output of the counter should be zero.
    As I dont know verilogA, i have tried to understand your code and modified it to include the enable input. Please refer the modified code below
    `define SIZE 4
    module counter (out,enable,clk);
    inout clk;
    input enable;
    electrical clk;
    electrical enable;
    parameter real vth = 1;
    parameter integer stepsize = 1;
    integer outval;
    analog begin
    if (V(enable)>vth)
    end
    end
    endmodule
    I am not getting any syntex error, But its generating the counter sequence irrespective of the threshold value.
    What went wrong.
    Please suggest.
    Vijay
    Your condition is in the wrong place. It depends what you want of course - in this case I made it so that the output only goes to 0 after the next clock edge by putting the condition inside the @cross branch for the clock:
    `define SIZE 4
    inout clk;
    input enable;
    electrical clk;
    electrical enable;
    integer outval;
    analog begin
      @(cross(V(clk)-vtrans_clk,1,vtol,ttol)) begin
        if (V(enable)<vth) outval=0.0;
        else outval = (outval +(+up- !up)*stepsize)%(1<<`SIZE);
      end
      end
    end
    endmodule
    Alternatively, you could have done (I only repeated the analog block here):
    analog begin
      end
     end
    end
    endmodule
    This will return the output to 0 as soon as the enable goes low (note, I assume you're not too fussed about precisely timing the enable transition so there's no @cross for enable)
  • vijaykpd
    Dear Andrew,
    Thats great. It works well for me. Thank very much for your time and support.
    Vijay
