  3. Cadence questions and Calibre
  • Views 18889
Pyroblast
Pyroblast over 10 years ago
Hi guys,
I'd like to ask a question, in first place, related to cadence. What the vault and mirror are and how they work?
Regarding Calibre, what does RVE means and what's its usefulness?
Kind regards.
    Neither of these questions are related to Cadence (the company) or the tools that we provide (I believe).
    The terms "vault" and "mirror" are usually associated with Design Management solutions (e.g. DesignSync, IC Manage, VersIC, SOS and others) which are from third party companies (Cadence connection partners). The term vault normally means the central repository for all the version-managed data, and the term mirror is used to refer to a local cache of a set of versions to allow more efficient access of a set of versions. You should contact your DM vendor for more details.
    Calibre is a product from Mentor Graphics. RVE is their debugging environment which interfaces to Virtuoso. You should contact them. A 2 second google search for "Calibre RVE" gave me this as the first hit:
  • Pyroblast
    Thank you Andrew. Taking the advantage of this post, can I ask you if you know any tool, hot-key or something like that which allows you to know the total area occupied by the layout of the block? I know that in the top right shows you the total XY size of the layout according to the mouse position and the default reference point in the layout. But what I want is to for example, select all the layout, press a hot-key so that Cadence gives me the total area and/or the XY of that selected block. It is not mandatory to be a hot-key, could be a tool. Regards.
    You could write this in SKILL. I don't have anything that does that already. Maybe somebody else already has something they created which does this that they could share (I don't have the bandwidth to write it today).
