  3. SYNTAX ERROR - Assura LVS
  • Views 1481
rafaelon
rafaelon over 10 years ago
Hello Friends from Cadence,
I have a schematic and layout and I want to check with LVS.
Sometimes, the LVS Tool works and other times not. In the last case, I am obtaining  the following strange problem:
SYNTAX ERROR found at line 1 column 19 of file *string*
*Error* lineread/read: syntax error encountered in input
******* Non-recoverable error (no top-level or error handler)
******* Exiting program ...
*WARNING* (reader): string at line 1 was not terminated on EOF, '"' added
                    at line 1 of string "1 0 (2129 "nmei"")"
*****  nvn fork terminated abnormally  *****
How could I fix this problem?
Rafael
    Please don't post twice (the forum guidelines tell you not to do this). This is the same issue as your more detailed post
    Cadence Technology Forums
    Cadence Technology Forums Mixed-Signal Design
    This Forum is in place to cover and discuss cross functional topics you may encounter designing and layout a Mixed-Signal Design.[br][b]Moderator:[/b] Andrew Beckett
    806 discussions
    AF202602026942 Spectre: Missing nodes in the operating point report. A configuration issue or a simplification? 21 hours ago
