  3. Can i make the design rule check blind to a specific layer...
  • Views 16172
Can i make the design rule check blind to a specific layer?
samer1
samer1 over 9 years ago
I am incorporating a device (memrsitor) in my layout that is not defined in the kit. I was thinking of representing the device by a layer that is not used in my design. However, this layer will have its own design rules that are different from the ones I want to set for my memristor?
So, I was thinking of using a layer that does not affect affect the DRC tool (the DRC does not show an error no matter where it is placed) or make the tool ignore the design rules for a specific layer and use that layer to represent the memristor. Is that even possible?
Any thoughts on that issue will be appreciated.
    This probably depends on whether you can (or want) to modify the DRC rule deck. If you draw everything on layers the DRC rules know nothing about, you probably don't have to do very much - see your other post Make a copy of the Kit
  • samer1
    So what do u mean by draw in"layers". Isn't that what we normally do?
    I said if you draw everything on layers the DRC rules know nothing about. I presume you don't normally draw anything on special layers that aren't known to the DRC rules...
  • samer1
    ah Ok. Got you. Exactly that is what I was getting at. So, is there an easy way to create a layer without messing up the kit (that is why I put my other question regarding making a copy of the kit). But if I can just create a custom layer for myself that does not bring about much hassle, I can just do it right away.
    Thanks Andrew
    Yes, my answer to your other question gives you an easy way to create a custom layer without disturbing the Design Kit.
  • samer1
    Ok. Thanks Andrew. I appreciate it.
