  3. ahdlLib opamp model vref pin
  • Replies 7
  • Views 30367
olalivier
olalivier over 9 years ago
Hi there, I try to use the opamp model from ahdlLib but there's a few point about the model I don't understand... 1. what are ibias and iin_max parameters ? 2. Is vsoft used for output clipping ? Concerning the pins, I really don't understand the point of vref...? I can't find a decent doc about the model and the code does not provide explanations... Can you please help me on this one and if needed tell me which other opamp with a slew rate limited output i can use. Thnak you very much. Olivier
    Andrew Beckett over 9 years ago +1
    The models are pretty old and from the early days of the SpectreHDL and then VerilogA standard. Some quick answers: ibias appears to be effectively a current drawn from the input pins to the reference…
    Hi Olivier, They're old, but that doesn't necessarily mean that there needs to be a more modern way necessarily. The models in bmslib are newer; the modelwriter models are similar in concept (although…
    1. ibias appears to be effectively a current drawn from the input pins to the reference node vref (which sets the common-mode reference for the output signal, mainly). iin_max is the maximum current the output stage can deliver (I think, from a quick glance) which is part of the slew limiting.
    2. vsoft is the voltage difference from the supplies that the output is soft-clipped to (actually it's fairly obvious from looking at the code).
    You might also want to try running the "modelwriter" tool (from the command line; although this is obsoleted too) which allows you to build an opamp model (with lots of comments) with whatever features you want. There are some other opamp models in bmslib (shipped in the same location as ahdlLib).
  • olalivier
    Hi Andrew and thank you very much for your answer. I do understand what you say about "pretty old" models but this brings a question, if I may. Is there a recent version of these libs or a modern approach to model this kind of devices without doing it myself. I know VHDL-AMS and I'm pretty sure I can do the same and tailor a device that does what I need but wouldn't it be more efficient to have something from lib ??
    Hi Olivier,
    They're old, but that doesn't necessarily mean that there needs to be a more modern way necessarily. The models in bmslib are newer; the modelwriter models are similar in concept (although structured slightly differently).
    It's just that because they are old, the developers are long gone and it's unlikely any new documentation is likely to be written. I did check resources such as the Designer's Guide web site but there didn't seem to be anything other than an ideal opamp model in the models listed there.
    So I would suggest you look at both bmslib and modelwriter (as that can allow you to tailor the models to what you need).
  • BaaB
    BaaB over 8 years ago in reply to Andrew Beckett
    From the code it seems that vref is reference node for output voltage. However, when I run the test Vout doesn't change when vref change over all range. So what is the function of it?
    This is the nest list:
    // Generated for: spectre
    // Generated on: Jun 16 16:55:17 2018
    // Design library name: TEST
    // Design cell name: Test_opamp
    simulator lang=spectre
    global 0
    // Library name: TEST
    // Cell name: Test_opamp
    // View name: schematic
    I0 (Vout VREF Vin net03 AVDD AVSS) opamp gain=1M freq_unitygain=30M rin=1T \
    vin_offset=0 ibias=0 iin_max=100u rout=10 vsoft=0.5 slew_rate=1M
    V5 (net07 0) vsource dc=1 type=dc
    VREF1 (VREF 0) vsource dc=0 type=dc
    AVSS1 (AVSS 0) vsource dc=0 type=dc
    AVDD1 (AVDD 0) vsource dc=5 type=dc
    Vin1 (Vin net07) vsource mag=1 phase=0 type=sine ampl=100.0m sinephase=0 \
    freq=1K
    R1 (net03 Vout) resistor r=9K
    R0 (net07 net03) resistor r=1K
    simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
    tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
    checklimitdest=psf
    tran tran stop=10m write="spectre.ic" writefinal="spectre.fc" \
    annotate=status maxiters=5
    ahdl_include "/home3/tool/IC616/tools/dfII/samples/artist/ahdlLib/opamp/veriloga/veriloga.va"
    Andrew Beckett over 8 years ago in reply to BaaB
    It's effectively an internal common-mode node; it doesn't have much (if any - I didn't exhaustively check it through) influence on the output (it might if the ibias is large enough, or you're slew rate limiting - I didn't really check through the equations in the Verilog-A code. You have the code, so you could work through that yourself.
  • BaaB
    Thank you. Actually I checked the code line by line and if I understood it correctly it is a common mode voltage for the output. However, it is strange that output common mode voltage doesn't change when I vary the vref.
    It's not strange at all. The opamp DC output voltage is defined by your feedback circuitry. Given that the two input pins must be (almost) equal (because of the high gain), and the dc level of the sinusoidal source is 0V, the voltage across both R0 and R1 will be 0V too. If there had been a dc component in the sine source, the voltage across R0 would end being the same as that DC component, and so the DC level of the output voltage would be 10 times higher (plus the 1V from V5). For example, if you set dc on Vin1 to 0.05 then the DC level at the output of the amplifier would be 0.5*10+1=1.5V.
    That's how opamps work. The Vref is just used in the output stage; it does not set the DC level of the output of the amplifier otherwise it would not operate correctly as an opamp.
