  3. Creating a symbol from a .scs file
  • Subscribers 136
  • Views 21226
samer1
samer1 over 9 years ago
I have a veriglog A model for a device. Earlier, I used to create a symbol from the verilogA model directly and all values preceded by "parameter" in the code would show directly in the CDF list of the symbol.
Now, I have an scs file that includes the verilogA model in it. I want to be able to create a symbol for that scs file and be able to include the scs file from ADL (model setup)?
I tried to use one of the devices in the analogLib "nmos" and include my scs file name in the CDF list but did not work as intended.
Can someone help with that?
  • Quek
    Quek over 9 years ago
    Hi Sherif
    There is no built-in, automated function to read the scs file and generate the symbol. You can do it as follows:
    a. Assuming that your scs file looks like:
    subckt myCell A B C
    ends
    b. Create a schematic with pins A, B and C
    c. Generate a symbol from the schematic
    d. Delete the schematic
    e. Copy the symbol view as "spectre" view
    f. In "CIW: Tools->CDF->Edit CDF" for the cell, go to spectre simInfo and add "A B C" as the "termOrder"
    g. Set the "componentName" as "myCell"
    You can now use the symbol in your schematic. Include the scs file as one of the model files during simulation.
    Best regards
    Quek
  • samer1
    Thank you quek very much
  • ghota3
    ghota3 over 8 years ago
    Hi Sherif and Quek,
     My spectre model file for which I am creating the symbol view that includes a veriloga model.
    I followed the steps as Quek said. But I can't know how to include my veriloga file into the model.
    When I tried to directly link the veriloga file in Setup-> Model libraries, but there were errors.
    Can you help me with that?
    Thank You.
    Andrew Beckett over 8 years ago in reply to ghota3
    If you're including a model file in Spectre syntax (e.g. myModels.scs) make sure that file has a line:
    ahdl_include "/path/to/the/veriloga.va"
    in it. There's no explicit include for VerilogA in ADE - typically VerilogA models are either created as views inside Virtuoso (in which case the netlister will add the ahdl_include statements), or via ahdl_include statements in an included spectre model file.
