  3. Should I use the PIN or the NET layer for gnd?
  • Views 15518
dpalomeq
dpalomeq over 9 years ago
I have a layout of a simple PMOS transistor passing DRC, LVS and QRC by using the PIN layer MET1 purpose for the 4 terminals and the connection for the general p-substrate (community.cadence.com/.../37368).
I have some doubts about this because the gnd! connection to the p-substrate is not a PIN in my PMOS cell. How should I implement the p-substrate connection then? Maybe with the NET layer MET1 purpose?
Thanks in advanced!
David.
  • Marc Heise
    Marc Heise over 9 years ago
    Hi David,
    really depends on the LVS ruledeck and what it recognizes as pin shapes. Usually you use layer "Met?" with purpose "pin"/"drw" to create pins. The
    "net" purpose is not something you should use. But again, it depends on your LVS ruledeck. You could flatten ( Edit-Hierarchy-Flatten) one of your
    instances ( pick a copied instance mos/resistor) as a test ( "Preserve Pins" in the flatten options ) and look at all the shapes to see how the PDK provider made them.
    Marc
  • dpalomeq
    Hi Marc,
    After some checks, I discovered that the right way was treating vdd! and gnd! in the same way than the rest of the pins (even though they are not pins in my schematics). Thus, I have placed labels in the PIN layer with purpose MET1 for all of them.
    Thanks for your help!
    David.
