  3. Parasitic extraction for interconnects
  • Subscribers 136
  • Views 21037
Fabio23
Fabio23 over 8 years ago
Hello all,
I need to run Calibre parasitic extraction (PEX) for some interconnects which are basically a combination of metal layers and vias. So no schematic corresponds to that, and I just have a layout consisting of metal layers. That is why LVS can not be run for that, and no PEX result can be obtained. I realized that we may be able to use some dummy resistors in the schematic (in the PDK that I use, I think they are called "lvsres") to create a dummy schematic. But "lvsres" has no layout in the technology library, it's just a symbol, so again no LVS can be run I assume. Does anyone know how to work with "lvsres", or how to run PEX for a cell with no schematic?
Thank you
  • Frank Wiedmann
    Frank Wiedmann over 8 years ago
    LVS resistors are often created by placing a special marker layer over a piece of metal. Read the manual for your PDK in order to learn how the lvsres works in your case.
  • Fabio23
    Thank you Frank. PDK manual doesn't provide any information regarding that, I was hoping to find out how it's done in other technologies (the special layer) and employ that in ours.
  • drdanmc
    drdanmc over 8 years ago
    look in the PDK for metal resistors. It would not be unusual to have them be filed under "resistor" category in a PDK and/or have names like rm1/rm2/etc or rmet1/rmet2/etc. And if this doesn't exist, you likely would have to add one. It is not too hard. A typical way would be a layer called something like "rrec" (for "resistor recognition") or "rmdummy"or "resmark". Then create a purpose for each metal layer. Then your device recognition just needs to look for metal+recognition layer. Then you can put one of these in series with a metal line and extract resistance between two pins on the same piece of metal.
