  3. detecting process corner from within verilogA model
  • Replies 20
  • Views 29046
SoniaMK
SoniaMK over 8 years ago
I need to create a model of a current source in verilogA but the value of the current depends also on the process corner. Is there a way for the verilogA model to detect what corner the simulation runs with? In ADEL we specify the corners through an include statement like this:
include <model file> section=typical
    I would suggest you have a parameter that is set in the corners (i.e. a global variable), and then pass that as an instance parameter to your Verilog-A model.
  • SoniaMK
    Thanks, Andrew, for replying. If I understand correctly your suggestion, it is to include a parameter in the model deck indicating the corners. Unfortunately, I can't touch the model files as they come from the foundry and are not supposed to be edited.
    Regards
    There's nothing to stop you defining your own wrapper around the foundry files which does something like this:
    library mylib
    section NN
    parameter corner=1
    include "foundry.scs" section=NN
    endsection NN
    section FF
    parameter corner=2
    include "foundry.scs" section=FF
    endsection FF
    endlibrary mylib
    Something like that... then you can include your wrapper around the foundry models and don't have to touch the foundry models in any way.
  • SoniaMK
    Understand. Thanks
  • HoWei
    HoWei over 8 years ago in reply to Andrew Beckett
    The correct Syntax would be "parameters"  - in Andrews example the "s" is missing.
    It took me quit a while to figure out why it was not working.
    Here is the correct Syntax (that is working in my modelfiles at least):
    library mylib
    section NN
    parameters corner=1
    endsection NN
    Andrew Beckett over 8 years ago in reply to HoWei
    Apologies - I just typed it in (probably on my phone) and didn't check it...
  • ElZorro
    ElZorro over 8 years ago
    Thank you, I am following this thread because I need to implement the same and I have a question.
    I have created a file called "wrapper.scs" which looks exaclty like this:
    library wrapper
    section NN
    parameters corner=1
    include "gpdk.scs" section=NN
    endsection NN
    section FF
    parameters corner=2
    include "gpdk.scs" section=FF
    endsection FF
    endlibrary wrapper
    In ADE-L I select Setup/Model-Libraries/
    then I select the path to the model file "wrapper.scs" and I can select between the two sections "NN" and "FF" (the original file gpdk.scs has more sections). So this part is working fine.
    My question is how to read the value of the parameter "corner" into the veriloga model. I am lost here.
    Thank you very much!
  • Saloni Chhabra
    Saloni Chhabra over 8 years ago in reply to ElZorro
    You can create a parameter in your veriloga model e.g. parameter real getcorner = 1; .  Based on the value of of 'getcorner', you can code the functionality in verilogA model using if/else.
    Then when you instantiate the model, you can pass it the value of 'corner' (coming from models) as:
     I0 (x y z) cellA getcorner=corner
    ahdl_include "/path/to/cellA.va"
    Saloni
  • ElZorro
    ElZorro over 8 years ago in reply to Saloni Chhabra
    Hi Saloni,
    thank you for your reply.
    Implementing the functionality in the verilogA model using the value of the parameter and if/else is clear.
    My question is how to pass the value from the "wrapper.scs" to the verilogA model?
    This is my file "wrapper.scs":
    library wrapper
    section NN
    parameters corner=1
    endsection NN
    section FF
    parameters corner=2
    endsection FF
    endlibrary wrapper
    This is my model "veriloga.va":
    `include "discipline.h"
    `include "constants.h"
    module inv(A, Y);
    input A;
    output Y;
    electrical A, Y;
    parameter real getcorner=1; // how to pass "corner" from "gpdk.scs" to "getcorner" of "veriloga.va" ???
    endmodule
    When I instantiate the verilogA model (cellview name is "veriloga_read_corner") in the schematic testbench I press Q (properties) and set:
    CDF Parameter of view      veriloga_read_corner
    getcorner                            corner
    But I get following error:
    nchelp ncelab CUBSPA
    ncelab/CUBSPA =
    Assigning a string value to a parameter which is declared to be either
    real or integer is illegal.
    In summary, what I am missing is how to pass the parameter value "corner" defined in "wrapper.scs" to the parameter "getcorner" inside the "veriloga.va" model.
    Thank you very much for your help.
  • Saloni Chhabra
    I just tried this on a small testcase and here's what I had to do. When you run netlisting from ADE, do you get a design variable called 'corner' added to the state? You can give the default value to 'corner' in ADE state e.g. 1, and then run the simulation. Spectre will then see variable corner being defined more than once, so depending upon your setup, you might get an error for the same parameter being defined twice. To get past that error, you can set Simulation option redefinedparams=warning. The value coming from models will override the value set in ADE. Hope this helps.
    Saloni
