  3. How the simulation performance mode :APS support the stimulus...
  • Views 16521
How the simulation performance mode :APS support the stimulus files?
nnlt
nnlt over 7 years ago
Dear all,
When I have a stimulus file, I can run well with the simulation performance mode: spectre. After running I can plot all the waveform. But when I use the  simulation performance mode: APS, I can't plot the signal waveform in the stimulus file after running. The net in the stimulus file I write: ([#...] 0).
  • Quek
    Quek over 7 years ago +1
    Hi nnIt Would you please check if COS article 20444507 can help to resolve your problem? You can either save those signals explicitly (e.g. save mySig1 mySig2) or add -rmdg as one of the userCmdLineOption…
  • Quek
    Hi nnIt
    You can either save those signals explicitly (e.g. save mySig1 mySig2) or add -rmdg as one of the userCmdLineOption.
    Best regards
    Quek
  • Nasser Arif
    Nasser Arif over 7 years ago in reply to Quek
    Hi Queck,
    In this case, APS shows any message in logFile?
    Nasser
  • Quek
    Quek over 7 years ago in reply to Nasser Arif
    Hi Nasser
    Yes, the following warning can be found in APS log file:
    Warning from spectre during hierarchy flattening.
        WARNING (SPECTRE-8530): Dangling node. aaa is removed.
    "aaa" is a dangling net that only exists in the stimulus file and not in the schematic. Using -rmdg option preserves dangling signals and the following can be then be found in the log file:
        Only one connection to the following 5 nodes:
            aaa
    Best regards
    Quek
  • nnlt
    hi quek
    thank you very much
