  3. Liberate for library file
  • Replies 23
  • Subscribers 131
  • Views 28500
fengye
fengye over 7 years ago
Hello, everyone! I have a problem with the usage of Liberate.  The error information is
*Warning* (write_verilog) : No function written for pin Q of cell balloon_sim_nognd
Then, I look at the verilog file, some information like that
module balloon_sim_nognd (Q, D, NRESTORE, SAVE, CK);
output Q;
input D, NRESTORE, SAVE, CK;
reg notifier;
wire delayed_D, delayed_NRESTORE, delayed_SAVE, delayed_CK;
// Missing function for pin Q
// Timing
I don't know the reason.
  • Guangjun Cao
    Guangjun Cao over 7 years ago in reply to fengye
    Is this a valid arc for this cell?
    cell=balloon_sim_nognd, pin=NRESTORE, related_pin=CK, timing_type=removal_rising, when=(!D * !SAVE), rise_constraint
  • fengye
    fengye over 7 years ago in reply to Guangjun Cao
    Hi Guangjun,
    This is the error  timing arc I have said. I am not sure if it's not valid for the cell.  NRESTORE is low-active and maybe an asynous input pin.  So, I use the write_template to get all the arcs from the incomplete lib file and run agagin with the given arcs, which the above error removal arc is eliminated.
    According to the definition, " Removal time for sequential cells is the minimum length of time at which the set or reset signal must remain after the active edge of the clock to ensure correct functioning of the cell. " I don't understant why there are so many arcs.
    Regard,
    Fengye
  • fengye
    fengye over 7 years ago in reply to fengye
    Hi Guangjun,
    After I set 'NRESTORE' as a Synchronous input, there are still more problems about the arcs. The all arcs generated by Liberate has a possibility of error. If it's true to eliminate some of them.
    Regared,
    Fengye
  • fengye
    Hi Guangjun,
    I looked the Liberate manual and find some commands like
    "read_library TSMC_balloon_ss_0p99v_125c_ecsm.lib
    # set timing check variables
    set vital_timing_violation_format "Tviol_edge"
    set vital_recrem_violation_format "Rviol_ref_edge"
    set vital_timing_info_format "Tinfo_ref_edge"
    set vital_recrem_info_format "Rinfo_ref_edge"
    # Output a Vital file
    write_vital TSMC_balloon_ss_0p99v_125c_ecsm.vhd"
    The the vhd file has some reminder about error, you know how this can help me deal this problem.
    Thanks a lot!
    Fengye
  • Guangjun Cao
    Hi Fengue,
    You can not simply ignore a failed arc characterisation. 'removal' constraint is like 'hold'. You should ask the designer to clarify whether this arc is valid. If it is, you can save the failed deck and do debug. there are suggestions in the logfile, which should be tried first. You can also save the passsed deck and use them for debug reference.
    For the function, you may have to add it yourself, as this cell may not be normal "standard", but a custom digital. the right function can only be provided by the cell designer and the STA digital engineer. You can also use a similar cell as a reference.
    Guangjun
  • Guangjun Cao
    Is this the same library? If so, it is meant to fail, as your library is not complete.
  • Guangjun Cao
    If 'NRESTORE' is NOT Synchronous, then you can not define it as Synchronous.
  • Guangjun Cao
    one quick question: does this cell pass characterisation on other corners, eg. TT?
  • fengye
    Hi Guangjun,
    Thanks for your reply! 'NRESTORE' may be asynchronous.  The error removal arc may be eliminated. Then the lib can be gennated without error, but still with warnning about "write_verilog". This same case can happer at SS,TT FF cornner.
    When the lib without above removal arc is used for synthesis, some warnning shows the balloon cell is unusable. This is the reason I want to analyze the correctness of the lib file.
    After you tried that, are the complete lib file generated?
    Regard,
    Fengye
  • Guangjun Cao
    Hi Fengye,
    I saw the failed arc, but did not try to debug it. It can be very time consuming and may need knowledge about the logic behavior of the cell. In any case, you need to find out if this arc is valid.
    It is not clear to me that the "unusable" warning is due to the removed "removal". What synthesis/tool are you talking about? can you get help on why this warning is issued? in general, a missing arc does not always cause problem.
    regards,
    Guangjun
