  3. Simulating MOS Varactor
  • Subscribers 133
  • Views 25130
wgtkan
wgtkan over 6 years ago
I would like to simulate the MOS Varactor to determine Capacitance versus frequency.
I looked through the forum and found old posts but It is not working for me.
https://community.cadence.com/cadence_technology_forums/f/rf-design/40895/multiple-y-param-results-for-varactor
I am attaching my test bench.
Thank you so much in advance.
    ShawnLogan over 6 years ago
    Dear wgtkan,
    I’ve had a lot of experience simulating varactor impedances over both frequency and voltage bias and should be able to help you a little.
    A couple of questions if I may...
    1. In your test bench, are you also intending to vary the DC voltage of your bias voltage “vtune”?
    2. What frequency range are you intending to cover? In your test bench, with the 100 H inductor in series with your device under test, my concern is its impedance is too large.
    3. I have provided a test bench in this forum that does what, I believe, you want if you are interested. Basically, it allows you to determine the C-V characteristic of the varactor at a given frequency. Let me know if you are interested.
    Shawn
  • wgtkan
    wgtkan over 6 years ago in reply to ShawnLogan
    Hello Shawn,
    Thank you so much for your response.
    My intention is the following:
    1. To plot the Capacitance versus the bias voltage which is vtune at 2.45GHz
    2. To plot the Capacitance versus frequency over the range of  1Hz to 3GHz.
    I have looked at your setup where you used Voltage source in series with an inductor making the two (the series connection of the voltage source and inductor) in parallel with an AC current source and then using an Iprobe that is connected to one port of the  Varactor and the other port of the Varactor grounded.
    I did AC sweep where my X axis is frequency and then went to direct plot > main form and plotted the voltage but weren’t able to get the real or imaginary showing up in the direct form window.
    I even tried the XVal function of the calculator by multiplying it with 2*pi and still nothing.
    What am I doing wrong?
    ShawnLogan over 6 years ago in reply to wgtkan
    Dear wgtkan,
    Perfect - I understand totally and should be able to help a little anyway.
    I think you need to open the Results browser, select the node voltage of interest and send it to the calculator. From there, you may use the real() and imag() functions to determine the real and imaginary components. You may then apply the value() function to get the value of the real or imaginary part at one or more frequencies to compute the effective capacitance or real part of the impedance (after dividing by the current through the device under test). I've assembled a zip file that contains a Portable Document Format file entitled "example_spectre_small_signal_impedance_test_bench_test_cap_smlogan_v1p1_060420.pdf" with an example test bench, ADE-L setup and analysis panel, and example C-V and Re{Zin}-V characteristics. I've also include the state file as a directory with the outputs and the exported outputs with the latter in the comma separated file "test_cap_smlogan_v1p1_outputs_060420.csv". From that file, you may view the ADE-L/ADE-XL/Assembler expressions to compute the impedances at several frequencies - or even import the file to your own test bench. Obviously, the state file directory I included will not load the models I am using in your environment. I only include it so you have a copy of the variables, analysis, and outputs. Finally, if you use ocean scripts, there is a sample ocean script file I use to compute the real and capacitive parts of a device under test and place them in a comma-separated variable file called "z.ocn". The only function it calls is getWave() which is just a version of getData() with some error checking. I included it as well.
    The zip file is attached.. Hence, download the file, extract its contents and take a look. Let me know if you have any questions wgtkan!
    Shawn
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/38/test_5F00_cap_5F00_smlogan_5F00_ade_5F00_L_5F00_sample_5F00_test_5F00_state_5F00_and_5F00_example_5F00_060420.zip
  • wgtkan
    Hello Shawn,
    Thank you so much indeed. I will give it a try today and will let you know.
