  3. issue in launching Technology file manager
  • Views 13198
skillEater
skillEater over 5 years ago
Hi
i am trying to launch Technology file manager.I am getting the following error.
*Error* eval;unbound variable - ciwvHelpMenu.
I tried different user and worksapces also.
Please Help me.
Ganesh Doddipatla.
    You asked exactly the same thing in 2019, and I answered it then...
  • skillEater
    skillEater over 5 years ago in reply to Andrew Beckett
    I did the same thing you told in previous mail.
    It is not working. Still getting the same error.
    Please help me.
    Ganesh Doddipatla.
  • skillEater
    can you send me the command I need to give in icfb.I will use the command.Now it is techManagerOpentechToolBox.
    Ganesh Doddipatla.
    Andrew Beckett over 5 years ago in reply to skillEater
    As mentioned in the other posts, use ddGetStartup("menus/ciw.menus") to find out where the old (outdated) menus file is located. You seemed to be able to find this before, and I suggested that you get the owner of that file to remove it.
    You've not even mentioned which versions of the tools you're using (you talk about "icfb" - the tool has not been called icfb for 15 years - presumably that is some local wrapper around Virtuoso.
    Perhaps you would be better off contacting customer support - since after several attempts to explain how to resolve this, you've not resolved it...
