  3. Global nets in the extracted view
  • Replies 8
  • Subscribers 137
  • Views 22747
iamKarthikBK
iamKarthikBK over 5 years ago
When I design a cell using the Virtuoso Schematic Editor, I name nets as local nets (a, b, vdd, gnd, and so on). When I draw the layout, these nets become global automatically (vdd! and gnd!). I later get errors telling that net gnd! is shorted to gnd.
How to avoid nets becoming global?
  • cdonovan
    cdonovan over 5 years ago +1
    I had a similar problem recently. What had happened was that someone had created copies of some logic PCells, both schematic and layout, and added explicit vdd and vss pins instead of using vdd! and vss…
    This seems a bit odd. I'm wondering if there might be some inherited connections (net expressions) on pins of your devices and the default values of those are causing global nets to be created - I can't think why else it might happen. Since I assume you can't share the design here, you probably need to speak to customer support.
  • iamKarthikBK
    iamKarthikBK over 5 years ago in reply to Andrew Beckett
    Andrew Beckett I went through https://groups.google.com/g/comp.cad.cadence/c/Dc6en4z3yig?pli=1 which is a conversation you had a few years back. Seems like this is something I am facing as well!
    My unit CMOS inverter is as follows (unfortunately I am not allowed to share any other designs publicly)
    The way I created these pins is Create -> Pin ;
    Direction: inputOutput
    Usage: Schematic
    Signal Type: power
    and everything else was left untouched. I am using IC6.1.8-64b .
    Similarly ;
    Usage: Schematic
    Signal Type: ground
    the pins "in" and "out" are given the directions "input" and "output" respectively. Their signal type is 'signal' instead of 'power' or 'ground'.
    Once this is done, I check and save the schematic and then Launch -> Layout XL -> create new ; Connectivity -> Generate all from sources; Create Labels for pins with the same layer and purpose (ME1 Drawing).
    Then Place -> Pin Placement ; Here is where I see that the pins are vdd! instead of vdd and gnd! instead of gnd.
    After this, I just routed the nets and performed DRC and LVS checks. Later I proceeded with the av_extraction and generated the post layout netlist using Quantus (Assura).
    Once this is done, I head back to the schematic, Launch -> ADE L and setup the av_extracted view before the others so that the parasitic are considered. (Is this required to generate the Netlist using ADE L -> Simulation -> Netlist -> Create?Because I already have the spice file which Quantus gave me.)
    Now what I need to do is Take these to Liberate and characterize them as a library so that I can port them into a synthesis solution and go ahead wit some synthesis runs.
    I am using UMC's 0.18u M FDK for all of this. My university has access to this through the Europractice consoritum. I will file the Case on customer support if I am not able to get help from here after this detailed explanation of the scenario, but the Pandemic is in it's peak here in India and the University is closed. Going through COS will be a time consuming process.
    thank you so much for your valuable time in advance, I hope I can get some help from here Slight smile
    Andrew Beckett over 5 years ago in reply to iamKarthikBK
    That other thread (on the comp.cad.cadence news group) isn't really relevant as that's about having global pins in the schematic, which you don't have. What is odd is that the schematic has normal pins, and they are converted to global pins (for the supplies only) on layout generation.
    Can you make your schematic window current (click in it somewhere) and then in the CIW enter:
    geGetEditCellView()~>nets~>name
    geGetEditCellView()~>nets~>term~>name
    geGetEditCellView()~>nets~>aliases
  • iamKarthikBK
    Here's what the CIW says:
    In text:
    ("vdd" "out" "gnd" "in")
    (("vdd")
    ("out")
    ("gnd")
    ("in")
    Here's what it says when I make the layout window current:
    In text:
    ("out" "gnd!" "in" "vdd!")
    (("out")
    ("gnd!")
    ("in")
    ("vdd!")
    Nothing obvious so far to explain why global nets have been used on the layout. A stab in the dark, but can you give the results of these with the layout window as the current window?
    geGetEditCellView()~>instances~>master~>nets~>name
    geGetEditCellView()~>instances~>master~>terminals~>name
    geGetEditCellView()~>instances~>master~>terminals~>net~>name
    BTW - I wouldn't worry about spending time capturing the images of the output - text is fine (and is better, as it's searchable and can be copied).
    Thanks.
  • iamKarthikBK
    Here you go!
    (("G" "S" "D" "B" "G_mustGroup_1"
    "S_mustGroup_0" "D_mustGroup_1"
    Okay!
    thanks
    Nothing unusual there either. I would suggest you report this to Europractice (you can find the contact details by searching for the europractice software service). In fact here it is http://www.europractice.stfc.ac.uk/contact_us.html
    if they can’t solve it, they will contact us.
  • cdonovan
    I had a similar problem recently. What had happened was that someone had created copies of some logic PCells, both schematic and layout, and added explicit vdd and vss pins instead of using vdd! and vss!. Then they edited the layout removing the  vdd! and vss! and placing the new vdd and vss pins there instead.
    All seems fine right? LVS and DRC clean, perfect. Unfortunately, somewhere in the layout properties it retained the idea that it had inherited connections, so any higher cell in the hierarchy that instanced the newly copied cell would get vdd! and vss! brought into layout whenever you either generated all from source or updated pins. Again, simply delete them and it always came LVS and DRC clean, so no issue, but an annoyance.
    The solution was to find the offending cell, for example the inverter described below, create a NEW blank layout (no memory of inherited connections), copy the drawn layers over to the new layout and save that, replacing the original with the weird inherited connections.
