  3. Dc level shifter
  • Views 12842
Dc level shifter
Khaleed01
Khaleed01 over 4 years ago
Hi i have a signal varying from - 0.3 to 0.5 volts
What's the simplest way to dc shift it all to positive value all by the same ratio
Like 0 to 0.8
    ShawnLogan over 4 years ago
    Dear Khaleed01,
    Like 0 to 0.8
    If you signal name is x, is there are reason you cannot create a new signal y with y set to
    y = x - ymin(x)
    Shawn
  • Khaleed01
    Khaleed01 over 4 years ago in reply to ShawnLogan
    The signal varying from - 0.3 - 0.5I s the output of a circuit and i want to use it in another circuit as input so i want to shift it
    ShawnLogan over 4 years ago in reply to Khaleed01
    Dear Khaleed01,
    Are you suggesting you are running a single simulation and want to shift the DC value of a -0.30 V to +0.50 V signal to create a new signal which is always greater than 0 for application tothe input to a different subciruit? I am still not perfectly clear as to what your needs are - sorry!
    If so, and you know a priori what the maximum and minimum voltage is for your bipolar signal, then you have at least two options:
    1. You could use a voltage controlled voltage source and apply an input voltage to offset your signal (see attached file for a full example)
    2. You could AC couple the signal input your next subcircuit using a resistive ladder to level shift its value.
    Without full knowledge of what your real need is, I thought I would at least pass these thoughts to you.
    Shawn
    test_vcvs_maestro_summary_051722.pdf
