  3. Cellview generation from VHDL code in cadence 618
  • Subscribers 136
  • Views 13480
rovin
rovin over 4 years ago
HI,
A beginer here for cadence,
I copy paste a wkng VHDL code from Vivado to cadence VHDL editor (Libray manager->file->new cellview : ... type :VHDL, open with : editor), save -> build a database of instancews,pins...   then following error is :
*WARNING* (TE-1308): Failed to perform syntax check for cellview 'CIS_v0 cnt_CTIA functional'.
*WARNING* (TE-1312): Compilation errors or warnings have been detected in the HDL file for cellview 'CIS_v0 cnt_CTIA functional'. To view the parse log for details, choose 'Parser Log File' from the 'View' menu.
*WARNING* (TE-4309): Extract failed for cellview 'CIS_v0 cnt_CTIA functional'
looking for any lead to resolve asap
thanks and regards,
rahul
  • delgsy
    delgsy over 4 years ago
    What works for me is importing the VHDL through CIW --> file --> import --> VHDL
    A few questions:
    1. Which IC sub-version are you using? (Help->About in any window will tell you)
    2. Do you have "XCELIUM" (or "INCISIVE" - although that's unsupported now) in your UNIX path? i.e. what do you get if you type "xrun -version" or "irun -version" in the terminal window?
    3. It suggested you look at the Parser Log File - did you look at this, and what did it say?
    4. Can you share the VHDL code you were trying to add?
    Otherwise, you've given an error message indicating that something is wrong with the code, without sharing what the code is and what the errors were. Pretty hard for anyone to diagnose that other than suggesting you do what the message said and look at the parser log file!
  • rovin
    rovin over 4 years ago in reply to Andrew Beckett
    Hi Andrew B,
    1. IC Version : IC 6.1.8-64b.500.26
    2. I am unable to run xrun, i tried to run in CIW command editor...seems this is not correct way, pls help me out for this.
    3. parser log file was blank file ...nothing here
    4.
    -- Company:
    -- Engineer:
    -- Create Date: 07/26/2022 05:56:16 PM
    -- Design Name:
    -- Module Name: cnt_CTIA - Behavioral
    -- Project Name:
    -- Target Devices:
    -- Tool Versions:
    -- Description:
    -- Dependencies:
    -- Revision:
    -- Revision 0.01 - File Created
    -- Additional Comments:
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    use ieee.std_logic_arith;
    use ieee.std_logic_unsigned.all;
    entity cnt_CTIA is
     Port (
     clk,ramp_enbl,comp_out,reset : in std_logic;
     count : out std_logic_vector (9 downto 0)
    end cnt_CTIA;
    architecture Behavioral of cnt_CTIA is
    signal cntr_dir : std_logic;
    signal q1: std_logic_vector (9 downto 0);
    begin
    process (ramp_enbl,reset)
        begin
        if (reset = '1') then
          cntr_dir <= '1';
        elsif (ramp_enbl'event and ramp_enbl = '1') then
        cntr_dir <= not cntr_dir;
        end if;
    end process;
    --process (cntr_dir)
    --begin
    --if (cntr_dir'event and cntr_dir = '0') then
    --   count <= q1;
    --  q1 <= (others => '0');
    --   end if;
    --end process;
    process (clk,reset)
    begin
    elsif (clk'event and clk = '1') then
        if (comp_out = '1') then
            if ((ramp_enbl and comp_out) = '1') then
                   if (cntr_dir = '0')then
                    q1 <=  q1 +1;
                    else
                    q1 <=  q1 -1;
                    end if;
                else
                q1 <=  q1;
                end if;
             else
          q1 <=  q1;
         end if;
    end if;
    end process;
    count <= q1;
    end Behavioral;
    Note : I even tried the verilog editor for simple inverter code
    (module veri (
    input x,
    output y);
    assign y = x;
    endmodule) ;
    following is error/warning log
    Error* _gets: argument #1 should be an I/O port (type template = "p") - nil
    *WARNING* (TE-1308): Failed to perform syntax check for cellview 'CIS_v0 veri functional'.
    *WARNING* (TE-1312): Compilation errors or warnings have been detected in the HDL file for cellview 'CIS_v0 veri functional'. To view the parse log for details, choose 'Parser Log File' from the 'View' menu.
    *WARNING* (TE-4309): Extract failed for cellview 'CIS_v0 veri functional'
    Looking for your kind suggestions..
    Andrew Beckett over 4 years ago in reply to rovin
    OK, I was talking about checking the "xrun -version" in the UNIX terminal window that you started Virtuoso from. The symptoms sort of look like that - check also "which ncvhdl" in that terminal window. For me, I get a popup saying it can't be found in my path.
    The code above compiles OK though if I do have the software set up correctly.
    If you can't get this working, I suggest contacting customer support - this should be easy enough to resolve with an application engineer being able to look at your setup.
  • rovin
    Error* _gets: argument #1 should be an I/O port (type template = "p") - nil : this error i got resolved, as i earlier do not have root access to the editor.
    Please confirm : AMS is required for working with cellview created with verilog code, as spectre can only handle analog simulation not digital one?
