  3. Difference between Transient and Transient+Noise simula...
  • Replies 15
  • Subscribers 137
  • Views 19229
Difference between Transient and Transient+Noise simulation
Senan
Senan over 3 years ago
Hello
I would like to ask about the difference between "Transient" and "Transient+Noise" simulation in Cadence Virtuoso.
For me I was thinking that what ever I get from running the transient simulation is what really I can see at my circuit output in time domain including noise, offset or any kind of disturbance,
But looking to have "Transient+Noise" makes me thinking that perhaps Virtuoso will only consider the noise contribution (Models) when we select this type of simulation.
Please I need your help for running the Transient+Noise setup
Thank you in advance
Best Regards
  • Frank Wiedmann
    Frank Wiedmann over 3 years ago +1
    Random noise (thermal noise, flicker noise, etc.) is not considered in a "normal" transient simulation. To learn about transient noise simulation, you can for example take a look at the Rapid Adoption…
    ShawnLogan over 3 years ago in reply to Senan +1
    Dear Senan, Senan said: Meanwhile I have other question, suppose I want to study the supply coupling noise of the supply voltage by connecting a source noise in series to the VDD of the circuit and then…
  • Frank Wiedmann
    Frank Wiedmann over 3 years ago in reply to Senan +1
    I would like to add that the pxf analysis can also be a very useful tool to analyze power supply rejection. This is shown in the Rapid Adoption Kits https://support.cadence.com/apex/articleattachmentportal…
  • Frank Wiedmann
    Random noise (thermal noise, flicker noise, etc.) is not considered in a "normal" transient simulation. To learn about transient noise simulation, you can for example take a look at the Rapid Adoption Kits at https://support.cadence.com/apex/articleattachmentportal?id=a1O0V000006Dd8UUAS and https://support.cadence.com/apex/articleattachmentportal?id=a1O0V000006DdEVUA0.
  • Senan
    Senan over 3 years ago in reply to Frank Wiedmann
    Thank you Frank for your answer, you made it clear with regards to the Random noise (thermal noise, flicker noise, etc.), I will read the resources you thankfully shared with me.
    Meanwhile I have other question, suppose I want to study the supply coupling noise of the supply voltage by connecting a source noise in series to the VDD of the circuit and then I will run the transient/transient+noise, is there a noise source generator in analoglib? or I have to modulate it different way to the suppy voltage
    Thank you once again
    Regards
    Dear Senan,
    If you are studying power supply rejection, I think it might be more insightful to modulate the supply voltage (staying within the design range of the supply voltage with your modulation amplitude) than using a noise source in series with the supply voltage. In this fashion, by applying a number of frequencies, you can establish the supply sensitivity of your design metric with frequency and amplitude. Using a transient noise simulation in its default state will include the noise of all other circuit elements. I would think it might be difficult to establish how much of the noise in your metric is due to the supply only.
    I might suggest you pass an ideal current I0 through a noisy ideal resistor R0 and use a voltage controlled voltage source to drive your circuit. Set the gain of the voltage controlled voltage source to 1 with its input as the nodes between I0R0 and its output your supply voltage terminals. You can select the value of I0R0 to be your nominal supply voltage. You may choose the value of R0 based the magnitude of thermal noise you wish to apply to the supply voltage.
    I hope I understood your question Senan and this helps.
    Shawn
  • Frank Wiedmann
    I would like to add that the pxf analysis can also be a very useful tool to analyze power supply rejection. This is shown in the Rapid Adoption Kits https://support.cadence.com/apex/articleattachmentportal?id=a1O3w000009fUcDEAU and https://support.cadence.com/apex/articleattachmentportal?id=a1O0V000009EVT2UAO (with an additional hint from me at https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/51605/using-sampled-pxf-analysis-to-simulate-deterministic-jitter).
  • Senan
    Thank you Frank and Shawn for your helpful answers and comments,
    I will study your comments  and resources before addressing the next question
    Best Regards
  • Senan
    Senan over 3 years ago in reply to Senan
    Hello once again,
    Actually what puzzled me after receiving our chip prototype from foundry is the alternative drop in the supply voltage due to the switching activity of the circuits in our chip.
    I admit that supply line disturbance is expected practically due to switching currents that develop a voltage drop on the supply output resistance. However, I am using LAB supply voltage where I am surprised to see him suffer like this, it is not simple LDO circuit.
    What I need to conclude, using an ideal voltage source is not the right when simulating Mixed-signal IC with Cadence (or any other type of simulation), for example, I have the same simulation setup of the measurement and I see that switching activity has zero effect on the supply voltage (ideal voltage source)
    Since I want to learn from my practical results and to make a more realistic simulation with Cadence in the future, I would ask for you suggestion for using the ideal voltage supply in the circuit simulation, like do I need to connect a small resistor in series to represent the output resistance.
    Thank you
    Best Regards
    Dear Senan,
    What do you mean when you state "alternative drop"? Are you describing a measured DC voltage at the supply pin (or pins) relative to the measured power supply at the power supply pins? Are you measuring the voltage drop between the pins of your power supply and an internal voltage within your IC? Figure 1 shows a conceptual diagram of a power distribution network, and I am not sure what nodes and measurement you are referring to.
    Is your netlist composed of a schematic or layout based (extracted view) of your subcircuit or IC? If an extracted view based netlist, is your extracted view a C only or RC based extracted view. Are there sufficient pins on your layout to properly represent its power and ground plane? A common problem is that only one or two pins are included for the supply and ground pins and all the subcircuit/IC current is forced to run through only a via or two which results in an excessive voltage drop not representative of the actual circuit.
    The best solution from the perspective of accurately estimating the voltage drops and switching noise is to use an RC based extracted view of your subciruit or IC where the layout of the supply and ground planes are included in the layout. Sufficient pins in the supply and ground planes should be included in the layout to reflect how they are actually connected. Tools exist to compute IR drops of a layout given an estimate of subcircuit currents from even a schematic view based simulation that are quite accurate.
    Using just a small resistor in the supply and ground nodes is probably a bit too simplistic as the supply and ground distribution networks are more complex as shown in Figure 1.
    I hope I understood your question enough to provide some helpful thoughts Senan. Let me know if I totally misunderstood your questions if I did.
    Shawn
    Figure 1
  • Senan
    Senan over 3 years ago in reply to ShawnLogan
    Dear Shaun,
    Thank you very much for your nice explanation and great effort you kept in your reply,
    I am actually and always do the post layout simulation in my comparison to my real measurement with RC extraction type.
    I mean by the "alternative srop", because the noise coupled to the DC source is AC, hence I mean alternative.
    I am measuring this disturbance at the IC supply pins of VDD and GND since I have no possibility to make internal IC probing because our chip is completely covered with a protection layer, I have no access to the IC internal nodes. So what I am doing is putting the oscilloscope probe at the VDD pin of the IC and monitoring its output, which shows the large amplitude noise coupled (like 700m Vpp).
    May be I am wrong, but I found it mysterious to see a noise coupled to the supply lines when I am using LAB power supply with thick probes. If I see this disturbance inside the chip then I can blame my chip power rings.
    With regards to the number of pins, I used 3 pairs of VDD and GND to power the chip, and they are evenly distributed around the chip. The number of via are carefully and generously provided to avoid this bottle nick.
    I have used thick metal in the power ring to reduce the IR drop.
    It looks from you nice explanation that I might have IR drop which I need to simulate using special tools which I have not used actually.
    Indeed what I always do is when I run the post-layout simulation, I print the DC voltage at a different place on the supply rails to monitor the drops for tracking the IR drop. If I am not happy with the IR then I usually increase the with of the rails metal width and using two layers at least one above the other when the width becomes excessive.
    Best Regards
    Dear Senan,
    Thank you for clarifying your term "alternative drop"! II now understand it is a peak-to-peak measurement of the apparent noise observed at the VDD and GND pins of your IC. I also found the details of the netlist you used in simulation, your layout methodology, and the measurement extremely helpful!
    I've had a lot of lab experience and can try to suggest a few items to consider if you are interested.
    1. Are you using a high-impedance probe or a 50 ohm probe. A high impedance probe will be very susceptible to EM and may show both the measurement and radiated noise- you cannot separate the two. Using a 50 ohm probe minimizes any radiative coupling.
    2, 3. Chip topology and internal bypass - see comment 2 in Figure 1.
    4. Where, what type, and how much external bypass is there between VDD and VSS?
    5. Are you observing he 700 mVpp "AC noise" on both the VDD and GND pins with your probe? Or is the 700 mVpp "AC noise" measurement between the VDD and GND pins? In other words, referring to Figure 1, which of the 4 measurement configurations are you using to take your measurements?
    My first guess is that the 700 mVpp measurement you are observing is an artifact of the measurement. With that much noise on presumably a 1 V DC supply voltage would cause massive circuit failure. If your measurement configuration was not exactly between the VDD and VSS pins, then the measured noise may be considered a common-mode noise element - still far too high - but it may explain why your circuit is still functioning.
    I hope I fully understood your answers to my first question and these thoughts are somewhat relevant and maybe even useful to you Senan!
    Shawn
    Figure 1
  • Senan
    Hello Shaun,
    I am deeply grateful for your explanation and the much of help and suggestions that takes you an effort to tackle our problem.
    I will answer your question one by one:
    1. I am using the 50 Ohm probe for measuring the supply noise, and for our chip circuit we used the 1 M ohms because our circuit, in particular, the amplifier prototype is not designed to drive a heavy load like 50 Ohm.
    2.3.  We distributed several bypass capacitors at the time of our chip design, but you know the range can not be more than tens of pico farad due to the die size constraint.
    4. Yes we connected bypass capacitors on our PCB board near to the supply, ground pins. We used a combination of 10 µF Electrolytic capacitor time plus 100 nF Ceramic type capacitor.
    5. We are measuring the noise like measurement configuration number 1
    6. Our package type is PGA 100 (Ceramic Pin Grid Array), one thing might be useful to mention, our chip area is small as compared to the package cavity but we used this type of package because we need 100 pins. As a consequence, the bonding wires are lonf to the maximum length allowed for packaging.
    Actually, the bonding wires was not considered by our simulation with its inductance, capacitance and resistance effect that also give an answer to the difference between out simulation in Cadence and the practical measurements we are observing. The highest level of simulation we performed is by including the pad frame. Even we are not aware if there is a simulation possibility that includes the package/bonding leads effect and could be interesting to know.
    I would like to share with you a snap screen from the oscilloscope measurement of the fully differential amplifier circuit. In this setup the amplifier both inputs are tied to the mild supply voltage, the same for the common mode voltage of 1.65 V where we use VDD=3.3 V.
    Ideally the differential outputs should be equal to VCM= 1.65 V as also proved by simulation, in addition to differential offset, however we set the closed loop gain to unity so th offset voltage should not be effective.
    When you look to the output you see the noise coupled at one of the outputs, Vout+ and also the noise coupled to VCM and VDD rails. Note that VDD and VCM are both provided directly from the power supply.
    I believe that noise should be random but what we see is deterministic noise looks like oscillation. On the other hand, we could use the ircuit to amplify by varying the gain level and also the SNR becomes better with higher signal amplitude, which means that if the circuit is still working as a linear amplifier cause if the circuit is not stable/oscillating it can not be used linearly.
    I am apologizing if I made the post lengthy and thank you once again for your kind help
    Regads
