  3. Cannot Install cadence IC618 on rhel 9
  • Subscribers 137
  • Views 18505
Aswin98
Aswin98 over 3 years ago
My institution have been using IC618 on rhel 7. Recently we decided to upgrade to rhel 9.
I am getting this error,
2023/05/24 13:48:33 WARNING This OS does not appear to be a Cadence supported Linux configuration.
2023/05/24 13:48:33 For more info, please run CheckSysConf in <cdsRoot/tools.lnx86/bin/checkSysConf <productId>
WARNING: not possible to detect OS, missing lsb_release command!
I understand that rhel no onger packages lsb_release.
Does this mean IC618 cannot be run on anything post rhel 7?
Is there a work around?
    Officially, IC6.1.8 is not supported beyond RHEL 7. That's because it is not routinely tested on (say) RHEL 8. There have been some fixes in ISR24 onwards (IC6.1.8-64b.500.24) so that it should run OK on RHEL 8 (I'm not sure about RHEL 9 - may be OK too). The next release (Virtuoso Studio) due at the end of June will support RHEL 7,8,9 officially.
    Which IC sub-version are you using?
  • Aswin98
    Aswin98 over 3 years ago in reply to Andrew Beckett
    Thank you for your reply.
    My institution uses IC6.1.8-64b.500.18
    I am guessing this version is incompatible. Should I contact the support team regarding getting the version you specified? Or do you recommend staying in our current version?
    Regards
    Aswin
  • revida marcos
    revida marcos over 3 years ago
    Good day! It appears that you are having trouble installing Cadence IC618 on RHEL 9. According to the error notice, RHEL 9 is not officially supported by the current release of IC618 and cannot be detected since the "lsb_release" command is not present.
    Even while it's possible that the most recent version of IC618 doesn't expressly support RHEL 9, that doesn't imply it can't be used with anything more advanced than RHEL 7. RHEL 9 does not support the "lsb_release" command, therefore you can run into compatibility problems.
    You can attempt the next methods to get around this:
    On your RHEL 9 system, install the "redhat-lsb-core" package. The "lsb_release" command that IC618 needs is provided by this package. Using the RHEL 9 package management, such as "dnf" or "yum," you may install it. For instance:
    sudo dnf install redhat-lsb-core
    Run the IC618 installation once again after installing the "redhat-lsb-core" package. Hopefully now that the "lsb_release" command is available, IC618 will be able to correctly identify the operating system.
    As the present version of IC618 may have additional requirements or constraints that are not explicitly addressed, keep in mind that this solution may or may not be able to resolve all compatibility concerns. It is advised to contact Cadence support in such circumstances for more guidance.
    I wish you success with your installation and good operation of IC618 on RHEL 9!
    Andrew Beckett over 3 years ago in reply to Aswin98
    Aswin,
    Your institution should be able to update to a more recent hotfix version than ISR18 (that you're using) - ISR24 is the minimum version which doesn't require you to mess around a bit with shared libraries (from my recollection). You can't yet move to Virtuoso Studio as it hasn't been released.
