  3. How to override the default values using Verilog netlist...
  • Subscribers 136
  • Views 7578
Omar Ghazal
Omar Ghazal over 2 years ago
I am trying to import a netlist to generate an array of verilog-a module block (for test doublerr. va).  I have already created a cell and symbol for this module.  when importing the netlist the array is made but with the default parameter values. how to override the default values?
doublerr. va
`include "constants.vams"
`include "disciplines.vams"
module vdoublerr (in, out);
input in;
output out;
electrical in, out;
parameter real parm1 = 0.2;
parameter real parm2 = 0.1;
parameter real parm3 = 5.0;
analog begin
V(out) <+ (parm1 + parm2 + parm3) * V(in);
end
endmodule
Netlist
`timescale 1ns / 1ns
module netlisting_500_schematic (clause, data);
inout [1:2] clause;
inout [1:4] data;
specify
specparam CDS_LIBNAME = "netlisting";
specparam CDS_CELLNAME = "netlisting_500_schematic";
specparam CDS_VIEWNAME = "schematic";
endspecify
vdoublerr I3 (.out(clause[2]), .in(data[4]));
vdoublerr I2 (.out(clause[2]), .in(data[3]));
vdoublerr I1 (.out(clause[1]), .in(data[2]));
vdoublerr I0 (.out(clause[1]), .in(data[1]));
defparam
I0.parm1 = 100.0;
endmodule
    Andrew Beckett over 2 years ago in reply to Omar Ghazal +1
    Omar Ghazal said: Any suggestion or hint, please. If this was urgent, you should contact customer support (this forum is responded to by people in their spare time). I didn't answer sooner because I…
  • Omar Ghazal
    Basically, I want to create an ( m × n )  array of a module in Verilog-A with parameters (para1, para2, para3). I intend to assign different values to these parameters for each device in the array. If there are alternative methods to achieve this, please share them. I also plan to use a script to automate the creation of this Netlist of the array. Thank you.
  • Omar Ghazal
    If this was urgent, you should contact customer support (this forum is responded to by people in their spare time). I didn't answer sooner because I was traveling and had no spare time.
    Anyway, a couple of choices. First you could use the defparam approach you suggested:
    inout [1:2] clause;
    inout [1:4] data;
    specify
    endspecify
    defparam I0.parm1 = 100.0;
    defparam I0.parm2 = 200.0;
    defparam I0.parm3 = 300.0;
    defparam I1.parm1 = 110.0;
    defparam I1.parm2 = 210.0;
    defparam I1.parm3 = 310.0;
    defparam I2.parm1 = 120.0;
    defparam I2.parm2 = 220.0;
    defparam I2.parm3 = 320.0;
    defparam I3.parm1 = 130.0;
    defparam I3.parm2 = 230.0;
    defparam I3.parm3 = 330.0;
    endmodule
    This creates a hierarchical property called "verilog" on each instance (which is not quite what you want). The good news is that you can fix it with SKILL as below.
    The other way you can specify the parameters is on each instance line, but it seems this only works properly if you also define a placeholder for the doubler in Verilog (not Verilog-A) at the same time:
    input in;
    output out;
    endmodule
    inout [1:2] clause;
    inout [1:4] data;
    specify
    endspecify
    vdoublerr #(.parm1(0.1),.parm2(0.4),.parm3(6.0)) I3 (.out(clause[2]), .in(data[4]));
    vdoublerr #(.parm1(0.2),.parm2(0.5),.parm3(7.0)) I2 (.out(clause[2]), .in(data[3]));
    vdoublerr #(.parm1(0.3),.parm2(0.6),.parm3(8.0)) I1 (.out(clause[1]), .in(data[2]));
    vdoublerr #(.parm1(0.4),.parm2(0.7),.parm3(9.0)) I0 (.out(clause[1]), .in(data[1]));
    endmodule
    This SKILL code can then be used (for both cases):
    procedure(CCFmoveVerilogParams(@optional (cv geGetEditCellView()))
      foreach(inst cv~>instances
        when(dbFindProp(inst "verilog")
          foreach(prop dbFindProp(inst "verilog")~>value
            putprop(inst prop~>value prop~>name)
          dbDeletePropByName(inst "verilog")
      schCheck(cv)
      dbSave(cv)
    Simply open the netlisting_500_schematic schematic and run CCFmoveVerilogParams(). I found a few requests to provide a way to directly import the parameters rather than to this verilog hierProp, but it's never been implemented.
  • Omar Ghazal
    Omar Ghazal over 2 years ago in reply to Andrew Beckett
    Thank you So much  it worked .
