  3. Buses in spectreText when creating symbol
  • Subscribers 136
  • Views 2601
MC20250412421
MC20250412421 over 1 year ago
Hello everyone,
This is a repeat of this question but since no one answered I thought I could ask it again.
If there are multiple pins A_0, A_1, A_2 in a spectreText view, can you merge them so that the symbol generated from this view shows a unique pin A<2:0> ?
This is basically having something analogous to the schematic view where it is possible to create bus pins like A<2:0> and the symbol would automatically include such pins.
Thanks in advance for your responses and have a great day !
    Andrew Beckett over 1 year ago +1
    If you can change the subckt names to be as follows (note the escaped angle-brackets): subckt textbus op bus\<3\> bus\<2\> bus\<1\> bus\<0\> r1 (bus\<3\> op) resistor r=1k r2 (bus\<2\> op) resistor r…
    r2 (bus\<2\> op) resistor r=1k
    r3 (bus\<1\> op) resistor r=1k
    r4 (bus\<0\> op) resistor r=1k
    ends textbus
    Then you will be offered to create a symbol with these names:
    op bus<3> bus<2> bus<1> bus<0>
    It's then easy to change to:
    op bus<3:0>
    but what will happen is that the terminal order will be recorded so that it knows the order they appear in in the subckt and so the netlist will be done correctly. For this to work, it really needs the names to be an expanded bus name syntax, whereas A_0, A_1 etc doesn't express any meaningful bus mapping from the A<3:0> to individual bits.
    That's probably the best approach. The challenge is that Spectre (like SPICE) does not have a bus syntax itself - so you need to ensure the names match what ADE would have netlisted them as.
  • MC20250412421
    MC20250412421 over 1 year ago in reply to Andrew Beckett
    Sorry for the late response, you are absolutely right, the bus syntax does work for a symbol generated from spectreText, I was under the impression it wouldn't but it just generates a warning and the rest works perfectly fine.
    This is great, I can have verilog A, schematic and spectreText (generated from PEX) cellviews to describe the same component and each support the bus syntax !
    Thanks again Andrew and have a great day/evening !
