  3. Recovering "actionable" netlist from GDS II
  • Subscribers 136
  • Views 3064
GS202507021424
GS202507021424 over 1 year ago
I'm interested in the extent to which one can recover usable netlist information from a GDS IIfile.
Assuming the GDS II was produced based on [gpdk|gsclib|giolib]045, and the original schematic (or Verilog source) was subsequently lost, I'm wondering if it is possible to recover enough information about the standard cell netlist to attempt redoing the synthesis (Genus) and place-and-route (Innovus) flows (presumably after having made some additional changes/edits to the netlist).
Right now, I can stream-import the GDS II into Virtuoso as a layout view. I can run Assura LVS to compare this against a dummy schematic: even though the comparison itself will fail, the run will produce an extracted netlist from the layout as a byproduct (*.ldb and/or *.lnnfiles, apparently generated via dfIIToVdb).
I dug around the documentation I could find, and while there's a lot of talk about dfIIToVldb, there's nothing on dfIIToVdb, and I'm a bit confused about what the difference might be between the two, and the output they produce.
I'm wondering what tools there exist to then view and/or convert the extracted netlist information (e.g., the aforementioned *.ldb/*.lnn file formats), into either Verilog or anything else that can be edited and passed back as input to Genus & Innovus for subsequent synthesis, placement, and routing.
Also, I wonder if there's a less roundabout way of extracting actionable netlist information (down to standard cells) directly from a GDS II file...
Any advice much appreciated!
    Andrew Beckett over 1 year ago +1
    I didn't see this post, but you could use vldbToSpice (or vldbToCdl) on the *.lnn file. There's nothing to output to Verilog. I suspect it might be a challenge to use the result as it will be missing meaningful…
    Andrew Beckett over 1 year ago in reply to GS202507021424 +1
    GS202507021424 said: What's the difference, if any, between running vldbTo[Spice | Cdl] on the *.lnn file versus on the *.ldb file ? <runName>.ldb The layout netlist containing the raw count…
    GS202507021424 said: and I wonder why these aren't matched to gpdk045 , which is (AFAIK) correctly configured in my cds.lib You would need to provide some device mapping file with SPICE IN to map the…
    I didn't see this post, but you could use vldbToSpice (or vldbToCdl) on the *.lnn file. There's nothing to output to Verilog. I suspect it might be a challenge to use the result as it will be missing meaningful names, but maybe it's better than nothing.
  • GS202507021424
    GS202507021424 over 1 year ago in reply to Andrew Beckett
    Thanks!
    What's the difference, if any, between running vldbTo[Spice | Cdl] on the *.lnn file versus on the *.ldb file ? The latter appears to generate additional attributes for each line of output (and overall seems to be a more "detailed" version of the former). Is the extra detail just useless for the stated purpose, or actively undesirable?
  • GS202507021424
    The other problem I'm running into is importing the *.cdl file produced from the *.lnnbyproduct of LVS.
    When I try Virtuoso → File → Import → Spice..., and fill out the Input pane:
    • Netlist File: .../chip_lnn.cdl
    • Netlist Language: CDL
    • Reference Library List: gpdk045 gsclib045 giolib045
    ... and the Output pane:
    • Log File: spiceIn.log
    • Output Library: foo
    • Process Technoloy File: Output View Type: netlist
    ... I end up with the following error:
    No subckt parameters for this module
        Instance: MavD13_1
        Instance has master: 'mos' model/subtype: 'g45p2svt'
            Master Cell: 'mos'.
            Did not find 'gpdk045.mos:symbol'.
            Did not find 'gsclib045.mos:symbol'.
            Did not find 'giolib045.mos:symbol'.
    ERROR (SPICEIN-24): Spice In did not find the symbol view of the master cell 'mos' of the instance
    There are references to the following devices throughout the *.cdl:
    g45n1svt
    g45n2svt
    g45p1svt
    g45p2svt
    ... and I wonder why these aren't matched to gpdk045, which is (AFAIK) correctly configured in my cds.lib...
    Any further help much appreciated!
    <runName>.ldb  The layout netlist containing the raw count of canonical devices
    <runName>.lnn The resulting normalized layout netlist after Assura consolidates parallel or series connected devices
    <runName>.sdb The schematic netlist containing the raw count of canonical devices
    <runName>.snn
    The resulting normalized schematic netlist after Assura consolidates parallel or series connected devices
    You would need to provide some device mapping file with SPICE IN to map the model names back to the actual devices in the library. The model names don't match the component names.
  • GS202507021424
    Thanks for the hint! Since this turned out to be a non-trivial endeavor, here's the map file I loaded (via the Device Map pane/tab of the Spice In dialog), as a syntax example for anyone else who might run into a similar problem and find this thread:
    devSelect := mos nmos1v
            propMatch := subtype g45n1svt
    devSelect := mos nmos2v
            propMatch := subtype g45n2svt
    devSelect := mos pmos1v
            propMatch := subtype g45p1svt
    devSelect := mos pmos2v
            propMatch := subtype g45p2svt
    This, along with a bit of manual massaging of the *.cdl file, allowed me to import into virtuoso as either netlist or schematic.
    Thanks again!
