  3. eco routing
  • Subscribers 93
  • Views 16986
eco routing
archive over 21 years ago
I am trying to do eco route (nanoroute with ecoroute = true). I can only do changes in M2 and M3 and in the vias V12, V23.
I am able to limit nanoroute to only use M2 and M3 with ""setNanoRouteMode routeEcoOnlyInLayers 2:3"", but how do I allow it to use V12 without using M1?
Originally posted in cdnusers.org by ChrisS
    Nanoroute should be able to do this automatically. If you are not using the latest release please try SOC41USR2. If you specify M2:M3 for frozen-metal ECO the router will create via12's if required to access the pin. If via12's are added the M1 of the via is placed entirely inside the M1 pin so the M1 mask does not change. If you are not seeing this behavior please open a Service Request with Cadence Customer Support.
    Originally posted in cdnusers.org by wally1
    Chris, in your flow, is nanoroute ripping up and re-routing
    all of the M2/M3, some (what it needs)of the M2/M3, or just adding to the current routing (new M2/M3 routing + existing M2/M3 routing).
    Do you need to ""fix"" the M2/M3 routing for the last choice? Can you do it this way?
    Any advice is appreciated...
    Thanks!
    Originally posted in cdnusers.org by KnightsWhoSayNi
