  3. Timing problems in multi cycle paths after partitioning
  • Subscribers 94
  • Views 21289
CT1Student
CT1Student over 17 years ago
Hi everyone!
I have a path (reg2out) that initiates in a partition and then goes to the top level and, finally, to an output. So far so good, but the problem is that there is no phase shift and no cycle adjustment (this is a multi cycle path and the launch and the capture  with two different clock domains), just a big external delay and if I put it to zero I am not able to meet timing. And the required time is negative.
This problem happened to others kinds (in2reg ...)off paths also.  As far I see, this is only happing for the multi cycle paths.
This path in the chip top is meeting time and have no problems, just after partitioning this is happening.
Do you have any ideas that may explain this problem, deal with, fix it, etc?
Best Regards.
  • Scrivner
    Scrivner over 17 years ago
    Can you post the multicycle constraint you have defined in your SDC file for this path and also the timing report for this path? Make sure the you have the number of cycles set to 2 (or more if needed) and make sure you have the from and to clocks defined correctly. Also check to make sure that the output pin constraint (set_output_delay) is referenced to the correct clock.
  • CT1Student
    Hi!
    Thanks for contributing!
    There is no problem in post the information that you asked, I just have to use fictitious names. ;)
    Lets start with the chip top constraints:
    set_output_delay -add_delay 2 -max -clock[get_clocks {clk1}] [get_ports {“MyOuput”}]
    set_multicycle_path 2 -end -hold -from[get_ports {“lots of others ports” “myOutput”}]
    set_multicycle_path 3 -setup -from[get_ports {“lots of others ports” “myOutput”}]
    set_multicycle_path 3 -setup -to[get_ports {“lots of others ports” “myOutput”}]
    set_multicycle_path 2 -end -hold -to[get_ports {“lots of others ports” “myOutput”}]
    Timing results for the chip top path:
    Path: Met Late External Delay Assertion
    Enpoint “MyOutput” clocked with leading edge of clk1.
    BeginPoint: “MyReg” triggered by leading edge of clk2.
    Other end arrival time: 4.167
    External Delay: 2
    Phase shift -4.166
    cycle adjustment : 16.66
    uncertainty: 0.125
    Required Time: 14.542
    Arrival Time 8.788
    Slack Time 5.754
    What Timing Debug window shows For the chip top level (I hope this is clear):
    |phase shift: -4.166| Data Delay: 8.788| External delay: 2| uncertainty: 0.125| positive slack|
    |O.E.A.T*. 4.166      | cycle adjustment: 16.166        |
      *Other End Arrival Time
    The constraints generated in timing budget just have the clocks “ clk1” and “clk2”and output delays. No multicycle path definition.
    Timing results for the partition:
    Enpoint “MyPartitionOutput” clocked with leading edge of clk1 (same as chip top).
    BeginPoint: “MyReg” triggered by leading edge of clk2(same as chip top).
    Other end arrival time: 0
    External Delay: 15.238
    Phase shift 0.001
    cycle adjustment
    uncertainty: 0.125
    Required Time: -15.362
    Arrival Time 0.876
    Slack Time -16.238
    What Timing Debug window shows for the partition
    | Data Delay: 0.876| External delay: 15.238             |
    |Negative slack: -16.238                                              |
    The problem here is that in the partition there is no phase shift or cycle adjustment and I can´t meet timing in this way, there is no way to “capture” the data, the slack is always negative, with or without the big external delay defined in the constraints files.
    Thank you for your time.
    Best regards.
  • Scrivner
    Ok - I misunderstood the specifics of the problem. But now I see that the issue appears to be in the generation of the timing budget constraints. I'm sorry, but this is out of my area of knowledge. In fact, I am also having issues with timing budget constraints generated for partitions. I had to submit a service request and am now working with a Cadence applications engineer on the problem.
  • CT1Student
     No problem!
    Thanks for your time!!!
    Have a nice week.
    Best regards.
  • bharath138
    bharath138 over 14 years ago
    Hi
    I am also facing  similar issue , did you find the solution for this problem ?
    Regards
    Bharath
